Author Topic: MK 4 Headunit Ignition feed  (Read 1884 times)
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« on: 16 November 2008, 18:53 »
Hi there. any of u guys ever experienced a loss in power from the ignition switched LIVE from back of the head unit?? Av tested it al with a multimetre and have gota constant LIVE for the permanent feed, but no ignition!? Av also checked every single fuse in th box in both primary n secondary fuse boxes yet they all appear to be fine!
Its actually a mates car am reffering to and av checked the obvious possibilities and have ruled out the fusebox. Only other thing I can think of is perhaps a break in the ignition wire sumwhere along its route where it is being compromised. Was thinking to suggest just to send a fresh wire feed from the back of the fuse box and run it as a replacement to the back of the headunit as a new ignition feed!? Any ideas otherwise???
Cheers!
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline troublestarter
Re: MK 4 Headunit Ignition feed
« Reply #1 on: 16 November 2008, 19:08 »
golfs are prone to developing faults with the ignition switch
although you have not mentioned what model it is as this is not a problem on mk4's
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline Ruji
« Reply #2 on: 16 November 2008, 22:32 »
umm...its a TDI as far as am aware..not my car...but a mtesbut hav onli realy got chance to see it recently and apparently its got transmission problems with the loss of its gear shifting ability...possibly the clutch....but that is a different problem anyhow!
wel the looms for the radio don't vary that much with any of the mk 4 golfs and are pretty much the same for most of the other vw and audi models without on board amps and bose systems.
