Author Topic: Sunroof help required please....  (Read 1182 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 14 November 2008, 17:30 »
Thinking of buying a Mk2 Scirocco tilt slide sunroof, as it's a direct fit. Has anyone done this conversion? Will my original outer sunroof panal fit the Scirocco mech? Any help appreciated.
sharpie
Re: Sunroof help required please....
« Reply #1 on: 14 November 2008, 17:31 »
mattneck's done it.
« Reply #2 on: 14 November 2008, 17:33 »
no you need to use all the rocco bits, the metal outer panel is totally different.  They sometimes drop right in easy, sometimes they fight you!  main thing to note is there should be a plastic pin on the end of both rails which locates in a round hole right inside the roof.  gotta get it in or the roof will jam up!
Offline dan7
« Reply #3 on: 14 November 2008, 17:36 »
Bl00dy hell! Two uber quick replies! Thanks!
« Reply #4 on: 14 November 2008, 17:43 »
a few of the other random parts are the same, for example the wind deflector and parts of the rails at the front.  you'll need to retrim the interior panel too, try to find a scrap headlining to cut up
sharpie
« Reply #5 on: 14 November 2008, 17:49 »
for best advice pm mattneck(beavis) off here or search for his project thread, since he's actually done it.
« Reply #6 on: 14 November 2008, 17:52 »
and so have I
sharpie
« Reply #7 on: 14 November 2008, 17:53 »
makes a change  :tongue:
Offline dan7
« Reply #8 on: 14 November 2008, 18:39 »
Come on now guys, calm down!!!  :laugh:
« Reply #9 on: 15 November 2008, 11:35 »
