Author Topic: air bag light  (Read 1126 times)
Offline faz186
air bag light
« on: 13 November 2008, 08:45 »
hey guys
1 day i was putting my cd player in and i had to take the glove compartment off to access the back, during the process i must have touched some wires and now the airbag sensor light is on,
ive put it on a diagnostic machine and it comes up with fault code 00589 airbag ignition circuit,
can some1 tell me that this is some wire come lose or have i messed the whole system up,
faz
Offline Paul86S2
Re: air bag light
« Reply #1 on: 13 November 2008, 16:35 »
00589 - Airbag Igniter; Passenger Side (N131): Resistance too High
Possible Symptoms
Airbag Warning Light active
Possible Causes
Wiring from/to Airbag Igniter Passenger Side (N131) faulty
Possible Solutions
Check Wiring from/to Airbag Igniter Passenger Side (N131)
Check Airbag Igniter Passenger Side (N131)
Retrieved from "http://wiki.ross-tech.com/index.php/00589"
I should check the wiring and make sure you haven't disturbed it at all.
When working on the airbag system you should disconnect the battery and wait 15 to 30 minutes after disconnecting in case there is any stored charge.
Paul
Offline faz186
Re: air bag light
« Reply #2 on: 14 November 2008, 08:49 »
thanks paul for that info, i think i must have disturbed it when squeezing my hands between the tight space at the back
cheers dood :grin:
faz
Offline leegt5
Re: air bag light
« Reply #3 on: 14 November 2008, 20:54 »
Or the slipring is knackered. If you've had the steering wheel off and not kept the slipring that sits in the rear of the steering wheel in the same position it come off then reattached the steering wheel with it not not in the original position then turning the steering wheel full lock it will snap the coil inside the slipring !!
Offline faz186
Re: air bag light
« Reply #4 on: 18 November 2008, 08:55 »
sorted thanks
i pulled the conection off the back of the airbag
cheers :laugh:
faz
