Author Topic: Fitting Recon head got some Q's  (Read 921 times)
Offline dirtydub
« on: 11 November 2008, 17:34 »
Hi all
Ive been getting stuck into taking my old head off today and ive come across one or two problems.
It says in the ever useful haynes manual that my injectors will just pull out from the head but im struggling to get them out and dont want to break anything is this correct? Do i just need to give them more welly or are there any other ways to do this?
Also im struggling to get at the manifold bolts how do I disconnect the exhaust manifold from the down pipe so i can just pull the head out and deal with it on the bench (need a special tool?)
Got tomorrow off again so will be carrying on with the job cant wait to get it finished no more tappet noise and no more smoke from the shot stem seals and maybe some gains from the port & polish  :smiley:
Sorry if these questions have been answered before im new here  :embarassed:
Car is '86 8v gti k-jet
Thanks in advance
Rich
'86 golf gti 8v k-jet project up and running :)
Re: Fitting Recon head got some Q's
« Reply #1 on: 11 November 2008, 17:53 »
k-jet inj are just pushed into the inserts, can take a bit of a yank!
if its the 6 bolt manifold you need a ton of extensions for your socket set and attack from underneath, or big spanners.  I try to take the mainold off the head instead though.  If you seperate the downpipe from the front silencer you can pull the head off with both inlets on!  Just put a blanket over the top of the block as soon as you crack the head loose to prevent it getting any knocks as you take out the manifold n downpipe.  It helps if you have a mate as its a bit awkward to lift tho.
« Last Edit: 11 November 2008, 17:55 by rubjonny »
Offline dirtydub
« Reply #2 on: 11 November 2008, 18:34 »
thank you RJ uve been helpful as ever
probably be back tomorrow night with a load more questions  :grin:
Rich
Offline Benrevs
« Reply #3 on: 11 November 2008, 19:02 »
As rj said, I found it easier to pull the mainifold out still attatched.. and defo get some help as i was IN the engine bay and got stuck as f**k! :embarassed:
Offline Conker
« Reply #4 on: 11 November 2008, 20:29 »
You pus#ys, I lifted a 16v head out on my own!!   :kiss:
Had to have a bit of a sit down after  :undecided:
« Reply #5 on: 11 November 2008, 21:41 »
head on its own isnt a problem, head with inlet and zaust manifold + downpipe attached isnt so easy ;)
Offline dirtydub
« Reply #6 on: 12 November 2008, 20:17 »
ur not wrong  :smiley:
my dad was to weak to help had to wake my brother who is workin nights (not impressed)
but got it out easily really, when u know how (thanks jonny)
getting a bit obsessed with cleaning polishing everything dunno if the new head will ever be ready to go on  :smiley:
Rich
« Reply #7 on: 13 November 2008, 11:43 »
carefull, these things can go too far.  for some reason i found myself trimming the moulding flash off my ABF coolant hoses  :grin:
