Author Topic: Running problems  (Read 2793 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Running problems
« on: 04 November 2008, 18:25 »
Ok where to begin. my car began running rough a few weeks back. I also changed the dash a couple of days ago for a better one. Since doing this the car is running really rough barely starting and hunting badly on idle. Done all the normal checks isv, vac leaks etc. Could i have disturbed something whilst the dash was out if so any ideas what??. There is also a grating noise comming occasionally when you rev the engine from the dizzy. I did have this off prior to removing the dash so again not sure if ive done anything here. Any help greatly appreciated
Offline Steve_B
Re: Running problems
« Reply #1 on: 04 November 2008, 18:58 »
Maybe you missed out an earth point when putting the dash back together? Think that would affect the dash more though.
Offline oakgreen_91
« Reply #2 on: 04 November 2008, 19:29 »
Did you forget to fit the vacuum hose to the back of the clocks?
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
« Reply #3 on: 04 November 2008, 20:07 »
yes ive put the hose back on the clocks. running out of ideas now  :cry:
« Reply #4 on: 05 November 2008, 12:15 »
have a look behind the centre console, maybe you dislodged the isv control unit and it doesnt liek you anymore? follow the wires from it anbd make sure non have popped off
« Reply #5 on: 05 November 2008, 21:19 »
ah good thought ill give that a go tomorrow
« Reply #6 on: 06 November 2008, 20:11 »
it seems the pipe was split on the isv. Also gave it a good clean. All is well at the moment  :smiley:
« Reply #7 on: 07 November 2008, 17:10 »
Still having major running problems. Starting still a nightmare. Foot on accelerator when first started and it hardley revs. exhaust also is popping occasionally. Revs plumet when you try to pull away. not to bad when warm but not brilliant. Ive noticed the saucer shape thing on the air box hasnt got 12v going to it. Should it be pushing air out?? could this explain my problems?? Car runs on lpg too and this is not running any good either. I'm running out of ideas now  :cry: :cry:
Offline danny_p
« Reply #8 on: 07 November 2008, 17:48 »
well if its running crap on petrol and gas    that shouts ignition   lift the bonnet withthe engine runnign at night  and look for sparks, check int he dizzy cap for oil ect
all the VW's have gone bar 1.
« Reply #9 on: 07 November 2008, 17:52 »
saucer thing only gets 12v with thottle open, its resposible for firing the 5th injector briefly when you put load on engine i.e. boot it.  but the 5th inj only gets an earth path when cold.  Perhaps the loom is shorting out for this, pull the plug on the 5th injector see if it improves.  I had mine unplugged for a week and it made no difference to how mine ran fregardless of stone cold or boiling hot!
edit: also if you have a spray bottle put a light misting of water over the ign components, check it at night like danny says, look for arcing.
