Author Topic: head unit wiring  (Read 3189 times)
Offline mmollart
head unit wiring
« on: 30 May 2004, 10:51 »
any body know what colours are for what in a mk3 16v?
Offline Dizzie
  • Make friends with your fast
Re:head unit wiring
« Reply #1 on: 30 May 2004, 15:39 »
red/white - power from fuse box
brown - earth
brown/red - ignition feed
black - aerial and booster (whatever they are)
white/yellow and grey/blue are to do with the lighting. you won't need these for an after market headunit
black/blue - Left front speaker
blue/brown - left front speaker
red/white - right front speaker
brown/white - right front speaker
blue/green - right rear speaker
brown/red - right rear speaker
brown/black - left rear speaker
red/green - left rear speaker
hope that helps :)
Mk4 Golf 150PD
Offline mmollart
Re:head unit wiring
« Reply #2 on: 31 May 2004, 13:53 »
cheers m8, your a star  ;D
Offline Dizzie
Re:head unit wiring
« Reply #3 on: 31 May 2004, 23:59 »
a star with a mk3 haynes ;D
Mk4 Golf 150PD
Offline vixteris
Re:head unit wiring
« Reply #4 on: 16 June 2004, 17:17 »
cheat  :P
vwsystems
Re:head unit wiring
« Reply #5 on: 24 June 2004, 00:55 »
normaly the iso block just connects into most new stereo iso blocks either on the back of the stereo or on the stereos wiring!!!......... the speaker connections are normaly ok its just that when you connect to power wires up sometimes they need moving to a different slot of the iso connector block so the match the cars iso connector..............
in fact i should get a job at a car stereo fitting place!
self taut when i fitted me own stereo! ;D
i also got a haynes car entertainment manual which has lots of info  in it!
