Author Topic: Need help fitting speakers and sub...  (Read 6017 times)
Offline daniel-1986
Re: Need help fitting speakers and sub...
« Reply #20 on: 29 October 2008, 16:24 »
parcel shelf speakers are the easiest to wire up just disconnect the standard rear speakers connect the wires to the 6x9's and front door speakers are a little bit more tricky if unless u can get the dash mounted ones out connect to them and run through the grommets in the doors and fitting a sub is just a pain in the ar$e doe a first time running the power through the bulkhead
