Golf mk2
battery and earth question
Topic: battery and earth question (Read 2165 times)
richard s
28 October 2008, 11:19 »
car has just sent battery flat again last week turned car over and clocks reset to zero and it was as if it was going to die then started so reset clocks and car ok then parked up friday after a good run and just went to start it and clocks reset again and battery died
i replaced battery a bit ago with a 063 44ah en390ccc can anyone confirm this is correct battery for car (1989 8v gti pb)
and also could it be a dodgy earth/connector not allowing car to charge properly while running if so which one is it most likely to be
i have put battery on charge and when it has a bit of charge i will pop down and see auto electrician to have starting/charging checked but last time it was ok (2years ago) but if he says its ok again im stumped
Last Edit: 28 October 2008, 11:43 by richard s
richard s
Re: battery and earth question
28 October 2008, 12:04 »
ive searched but cant find anything really relevent its ok till it comes to around winter then it starts
come on guys i dont want to go through this for another year
also what plugs do i need im sure rj recomended some in a post that were beru and different to what ecp lists for golf 8v gti (ive searched but cant find that either) and plug leads looked on ecp and cant find beru ones all it says for manufacturer is bbe are these any good
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
28 October 2008, 12:19 »
avs list beru single probe plugs for a digifant 8v, i recommend you use the k-jet listed tripple probes for no other reason that the single probe ones can be bashed out of spec in transit, tripples do not.
logeyboy
Here all the time
28 October 2008, 12:30 »
I had a very similar problem recently with mine.
The battery you've fitted should be fine.
I took mine to Chapmans Auto Electricians near Neepsend and he cleaned some corroded wiring etc and it's all fine now.
Cost me £40, money well spent.
Give them a call 0114 2724541
JC
10k hero
Back in the North.
28 October 2008, 12:51 »
can u get the use of an multimeter
rubjonny
10k hero
28 October 2008, 12:55 »
forgot to say, halfords will test your battery for free
might be you have a volt drain somewhere, fold your rear seat forward and make sure the boot light switches off!
richard s
Reply #6 on:
28 October 2008, 16:41 »
boot light doesnt work (would alarm led draw enough power to be a drain)
i have a multimeter somewhere but can never remember what setting is for what
do you know what wiring was cleaned up
after a few hours charge it was as if a new battery had been fitted but where the earth lead from gearbox fastens behind the battery it looks as if something else should be fastened there aswell ?
and do silicon ht leads go hard as some of mine are
cheers for the plug advice
also as i use a 2e dizzy would i need a 2e dizzy cap or a pb one
cheers guys
rubjonny
10k hero
Reply #7 on:
28 October 2008, 16:50 »
cap is same one regardless! clean up all the battery, starter and alt wires. does your battery light come on with the ign then go out when car started?
GolfDan
Here all the time
Reply #8 on:
28 October 2008, 17:02 »
I had a voltage drop through main earth strap that was on the engine mount. It were all corroded took it from there and onto gear box and no probs since.
richard s
Reply #9 on:
28 October 2008, 18:33 »
battery light comes on then goes off when started as it should (it doesnt flicker when running or anything it stays off)
i havent checked to see if i have an earth on engine mounts if i dont which one should it be on and where should it earth
just to be on the safe side how many earths should it have and where should they be
i will be cleaning all connections suggested at weekend
cheers for the help
Golf mk2
