Author Topic: battery and earth question  (Read 2182 times)
Re: battery and earth question
« Reply #10 on: 28 October 2008, 18:45 »
you have the main battery -v wire which runs to the battery tray, and either the gearbox mount or a stud on the rearmost gearbox -> engine bolt.  The latter is a much better earthing point as its direct to engine block via the bolt, rather thru a cruddy mount arm, then box, then then engine.
Offline richard s
« Reply #11 on: 28 October 2008, 19:08 »
ok so ive got the battery -v to batt tray then to gearbox bolt and ive got rocker cover to (i think)coil bracket
is this all i need
thanks again
« Reply #12 on: 30 October 2008, 11:25 »
thats the minimum aye, as long as they're good and clean it should be enough.  have you checked the voltage on batt tyerminals with a multimeter yet?
Offline Organisys
  • Old and Slow...
« Reply #13 on: 30 October 2008, 13:47 »
^^^check the battery voltage with the car running, see if the alternator is good.
Offline daniel-1986
« Reply #14 on: 30 October 2008, 14:28 »
im having the same problem since i converted my 1.3 to a five speed. ive checked the battery with a voltmeter which fluctuates between 12.2v and 12.3v with the engine switched off and 14.1v when running and come to think about it with the gearbox earth the car i got it off didnt have one connected to the gearbox should i connect it to the rear gearbox mount.
Offline richard s
« Reply #15 on: 30 October 2008, 22:35 »
cheers guys
i will try and find multimeter this weekend and clean the earth terminals and see how we go
