Author Topic: Boost Leak....  (Read 6625 times)
Offline RedRobin
Re: Boost Leak....
« Reply #20 on: 24 October 2008, 12:53 »
only had it on the rollers once (JKM rolling road day) since i had it mapped in January.  Custom Code qoute 170bhp and 280lbs ft torque - the torque i reached but not until 2600rpm
i've done 4 full throttle runs in 4th and noticed that at 1700rpm my MAF and intake pressure are well below the specs yet from then on i pull over and above what the ECU is requesting
 :undecided:
its awkward getting someone to look at it as there aren't any decent tuners / VW garages near me and the nearest CC agent is 80 miles away!
....JKM are about 90 miles away from me but I have lots of free time. It just needs someone who knows what to look for and how to fix it - Easier said than done!
Offline Rhyso
Re: Boost Leak....
« Reply #21 on: 24 October 2008, 12:59 »
all too true sadly!!  :sad:
i'm confident its not a big problem as i'd be loosing performance throughout the rev range but i'm not  :smiley:
Offline RedRobin
Re: Boost Leak....
« Reply #22 on: 24 October 2008, 13:09 »
Glad to here your well on your way to getting it sorted Robin :afro:
....Cheers, Steve :afro:
It would be good to see RED back to full strength to show the overweight and less-agile R32 boys a thing or two at Weston next weekend?  :grin: :grin:
....I won't be at JKM until Friday (the day before Weston), so I think I'll have to cancel :sad: - I'll contact them and explain my situation.
Offline RedRobin
Re: Boost Leak....
« Reply #23 on: 24 October 2008, 13:11 »
....Same here, but you need to watch that your turbo isn't overstressed.
Offline joesgti
Re: Boost Leak....
« Reply #24 on: 24 October 2008, 13:13 »
did you not read my reply??  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline RedRobin
Re: Boost Leak....
« Reply #25 on: 24 October 2008, 13:46 »
....Did you mean me, joe? - I did read it and my intention was to thankyou but tell you how 'useless' I was at getting under cars.
:afro:
Offline chungster
Re: Boost Leak....
« Reply #26 on: 24 October 2008, 21:40 »
Robin,
Tell Jim to take the boost gauge piping off at the Forge 3 port sender thingy..then do a run.
Just to rule out a leak in the boost pipe routing anyway.
Good luck and hope u find the leak.
Offline RedRobin
Re: Boost Leak....
« Reply #27 on: 24 October 2008, 23:42 »
Robin,
....Cheers for the tip :afro:
Offline RobGTI
Re: Boost Leak....
« Reply #28 on: 25 October 2008, 12:48 »
Would you be able to tell you had a boost leak from the VAG-COM? I'm thinking of getting one and it would be another reason to go ahead if I could check fault codes for things like this, as I have spent time and money getting my car into in current state of tune and don't want it slowly loosing power through soemthing like this.
Edition 30, Black, 3 dr, Manual, Xenons, Highline, Sunroof, Armrest, Cruise, Touchscreen Nav & Bluetooth.
Offline 182_blue
Re: Boost Leak....
« Reply #29 on: 25 October 2008, 13:10 »
im pretty sure you can test boost on Vag com and therefore spot a problem if there is one
