Author Topic: Hunting and stalling....!  (Read 2545 times)
Offline raks.2008
  • 1992 MK2 16V
« on: 21 October 2008, 13:08 »
Ever since the timing, leads and coil has been replaced the car sometimes stalls when the revs drop between changing gears. The other problem is that the car seems sometimes hunts when hot sitting in traffic or standstill.....
Can any1 please help.... I have checked for vacume leaks and the only outcome was the air intake pipe going onto the throttle body has is slightly split where the jubilee clip sits...
Anyw suggestions...
Thanks
Offline ToddyGTi
  • I Love GTi's
Re: Hunting and stalling....!
« Reply #1 on: 21 October 2008, 13:13 »
I'd check the ISV. Some ppl will alter the timing slightly to compensate for this being broken.
Part of the Booty Club
Offline raks.2008
  • 1992 MK2 16V
« Reply #2 on: 21 October 2008, 13:25 »
I have checked the ISV, by removing the pipe going to the main intake and the car cuts out, which means the ISV is running if i am not wrong...
It only happens when the car is warm.... funny one that...
« Reply #3 on: 21 October 2008, 14:52 »
if its an 8v check the idle switch on bottom of tbody clicks with throttle shut and wires behind tbody it havent snapped
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« Reply #4 on: 21 October 2008, 15:22 »
This is what my car is doing, when its cold in the morning its fine, but when it gets warm it chugs a bit and cuts out when the revs drop!!!
Its doing my head in!
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline mattkh
« Reply #5 on: 21 October 2008, 20:04 »
This is what my car is doing, when its cold in the morning its fine, but when it gets warm it chugs a bit and cuts out when the revs drop!!!Its doing my head in!
Hi
What engine have you got.
Offline Khare
  • The bear that khares
« Reply #6 on: 21 October 2008, 20:10 »
give the ISV a nice clean with petrol. let it soak overnight in petrl then in the morning give it a clean with a small brush or something.
Offline cняis
« Reply #7 on: 21 October 2008, 23:04 »
check the flying saucers rubber grommet (on the head)... i may have split and you may not have noticed it  :wink:
Offline raks.2008
  • 1992 MK2 16V
« Reply #8 on: 24 October 2008, 07:04 »
Hey....
Sorry about the late reply... been working out of London....!
The ISV is new and checked if it is working, by remoding the rubber pipe leading from it to the air intake pipe and it cuts out and the ISV starts buzzing, which is an indication sign that it works....
Chris you mentioned the flying saucer grommet. Where is that? sorry for being a dumb nut...lol
Thanks mate... :wink:
Offline Conker
« Reply #9 on: 24 October 2008, 08:31 »
Is it a 16v ??
