Author Topic: How much power?!  (Read 1732 times)
Offline plasticfantastic
How much power?!
« on: 20 October 2008, 14:32 »
Hi all,
Im after a few guestimates on how much power i am likely to get from new engine?!
Im currently building a 2ltr 8v (PB head) for my mk2,
This weekend i have been porting and polishing the head, not quite finished yet, but getting there!
All ports have been matched to manifolds and gaskets,
The throttle body will be flowed and polished too, also i am running a Piper 276 cam and i will be fitting a new set of injectors.
Any ideas what i can expect from this?!
cheers all
Offline Horney
Re: How much power?!
« Reply #1 on: 20 October 2008, 15:11 »
150ish I would have thought.
Nick
« Reply #2 on: 20 October 2008, 15:15 »
Nick
wow! I'll be well chuffed if i get near that! :cool:
will be happy with 130+ really...........
Anyone else here done similar mods, with figures?!
cheers all
Offline Benrevs
« Reply #3 on: 20 October 2008, 15:18 »
I have a 2.0 with pb head which is ported and polished and ive got more torque than anything.  But as nick said with the cam an manny you should see about 150. :wink:
« Reply #4 on: 20 October 2008, 15:21 »
How much torque?! :huh:
Offline Horney
« Reply #5 on: 20 October 2008, 15:22 »
Nick
cheers all
Well dubslug off here has the same spec as you but with a Polished and Ported head he bought from a proper tuner and that pulled about 155bhp.
Nick
« Reply #6 on: 20 October 2008, 15:27 »
Wicked! cheers,
thats given me a bit of a kick to finish it now! :smiley:
Dont suppose anyone has any pics of a pro port polish job?!
cheers all
p.s How restrictive are the original rear exhaust silencers?! to go with the new manny i plan to make a new centre section out of 65mm tube, replacing the centre box. Would i gain much more by replacing the rear boxes? I really dont want it too loud though........
« Last Edit: 20 October 2008, 16:45 by plasticfantastic »
Offline Benrevs
« Reply #7 on: 20 October 2008, 17:24 »
With that manifold you need as many boxes as you can fit!:grin:  Your better off getting some kind of system so that it retains flow but keeps the noise down. I had a pipe replacing the first silencer and it was really loud, i fell out with the neighbours over it! Oh and get it done!
« Reply #8 on: 20 October 2008, 17:50 »
cheers afghan socks!
any other mods/recommendations you have for the 2ltr conversion?!
thanks again for all your help
Offline ReDBull
« Reply #9 on: 21 October 2008, 14:06 »
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
