Author Topic: MK2 kjet abf Smoking  (Read 3919 times)
Offline Diluxe
« on: 20 October 2008, 12:58 »
Hi All,
I only drive my golf one day a week to work 15 miles to keep it turning over, today i noticed it struugled to turnover, and would keep misfiring, the moment i took my foot of the accelerator, it would just die, kept my foot on the accelerator and got it going  again but there was blue smoke everywhere, held it at about 2k revs until the misfiring , (smoke dissappeared about same time) disappeared and it idled on its own around 1k.
Drove to work no smoke no isuues , no high temps, any ideas whats causing the misfire & heavy blue smoke?
cheers
1997 16V
sharpie
Re: MK2 kjet abf Smoking
« Reply #1 on: 20 October 2008, 13:10 »
blue smoke would suggest it's burning oil. missfire could be something to do with the timing, did you check it when you done the conversion?
Offline Diluxe
« Reply #2 on: 20 October 2008, 13:13 »
yeah timings all good, went through MOT about 2 months ago, had the CO adjust then , and its been ok, not mad powerful, but started everytime no problem, if its burning oil, does that mean major money spend?
1997 16V
sharpie
« Reply #3 on: 20 October 2008, 13:18 »
depends how much oil it's using. if only a wee bit it might be stem seals, or more could be piston rings. did you get it compression tested at any point? might be worth a shout.
Offline Diluxe
« Reply #4 on: 20 October 2008, 13:20 »
yeah a couple of months ago, everything seemed fine.
I did replace the stem seals, and change the headgasket,,,, could something have gone wrong there?
It hasnt done alot of miles since conversion, 500 hundred tops
1997 16V
« Reply #5 on: 20 October 2008, 15:06 »
how long has the fuel been in there?  pop off the dizzy cap and make sure its not full of oil, take off the fei & tci plugs check for corrosion etc.  worth running it at night too, check if you can see anything arcing anywhere.
Offline Diluxe
« Reply #6 on: 20 October 2008, 15:14 »
i only ever put in a tenner in at time, and it lasts me 2 weeks, whats efi & Tci plugs mate?
1997 16V
« Reply #7 on: 20 October 2008, 15:19 »
fully electronic ignition = basically what people call the 'ecu' even though it isnt technically!
transistorized coil ignition = the wee metal 7 pin thing screwed to the bracket above the fei :)
fuel should be ok, had a prob with my mates car due to old fuel!  worth checkin the in-tank lift pump works, pull the plug off the main pump and turn the key 1 click, lifty pump should be heard to prime
Offline Diluxe
« Reply #8 on: 20 October 2008, 15:24 »
ah those two  :grin:
yeah checked the lifter pump at lunch time today, pulled the plug of the main pump, it buzzes not very loud , but can be heard
1997 16V
« Reply #9 on: 20 October 2008, 15:31 »
that'll be reet then, perhaps you have leaky injectors and/or 5th injector, fillin a cyly up wi fuel
