yeah you should get 12v at the white wire on the saucer with the throttle open, 15a is the 2nd spade terminal on the starter motor, which generally only k-jet motors have. If you only have 1 spade on the starter then you dont have a 16v starter motor, though all this means is you wont get any fuel spray from the 5th injector when turning it over on the starter stone cold. I had my 5th injector unplugged for ages and it didnt seem to make any difference, I dont think it gets cold ienough in the UK for the 5th injector to be needed really.
