Author Topic: New tyres - Pulling to the right  (Read 2119 times)
Offline Luck1ng
« on: 20 October 2008, 12:53 »
Just had the front tyres changed at 20k (Continental SportContact 2 ) However almost straight away after this, the car is pulling to the right - I've checked the tyre pressures and they are both at 34
Any ideas?
Thanks in advance
Offline Rhyso
Re: New tyres - Pulling to the right
« Reply #1 on: 20 October 2008, 12:55 »
tracking been knocked out?  :undecided:
Offline Top Cat
« Reply #2 on: 20 October 2008, 13:01 »
Did you stay with the car when fitting and also who did the fitting.
Offline Saint Steve
« Reply #3 on: 20 October 2008, 13:03 »
Worn road surface, ie heavy goods slow lane???, or likes been said , get the Tracking checked out , return it to the Garage who replaced the rubber.
They have put the wheels back on the correct side by any chance??
Offline Luck1ng
« Reply #4 on: 20 October 2008, 14:42 »
Thanks for the replys guys, Must be the tracking - I've checked everything else I can think of! =[ how much to correct tracking?
Offline Rhyso
« Reply #5 on: 20 October 2008, 14:45 »
should be no more than £20 - most places do a check for free and then charge if it needs to be done  :smiley:
Offline JoeGTI
« Reply #6 on: 20 October 2008, 15:16 »
I had exactly the same problem, only I had changed just one front tyre after pot hole damaged the original. The car pulled noticeably under acceleration. I eventually swapped the rears to the front and that solved it.
Offline Teutonic_Tamer
« Reply #7 on: 21 October 2008, 16:55 »
Are the new tyres both from the same batch?  It is not unknown for different batches to have small differences in the rubber compound - either through manufacturing tollerances or just down to ageing.
Swap the front wheels left to right, and see if it pulls in the oposite direction.
I feel like a homo
Offline Luck1ng
« Reply #8 on: 15 February 2009, 20:38 »
I guess they might be, I think the tyres are rotational, would it still be ok to swop the 2 front tyres around?
Just had a full geometry check and it's still pulling to the right!
Thanks for your help!
Offline ub7rm
« Reply #9 on: 16 February 2009, 12:50 »
I had my tyres changed on Friday and when I gave it the beans yesterday in second there was a definate pull towards the right.  Didn't get the chance to replicate the problem to see if it was the road surface to blame.  Am getting the alignment checked at the end of this week  (last set of tyres were badly worn on the inside) so hopefully will sort it.
Other than this issue which I hope is nothing to do with the actual tyres - Falken FK452's are fantastic.  The grip cornering wet and dry has transformed the car, and made it quieter too.  Was running dunlop sport maxx previously and thought they were decent but in comparision they are a load of shyte.
2020 BMW 128ti
2017 Golf GTD Estate
