Author Topic: Dump valve?.  (Read 3203 times)
neo66
Dump valve?.
« on: 19 October 2008, 19:51 »
Can anyone recommend a good dump valve please?(prefably a neat quiet one!) and could this void the warranty also? opinions please.
Offline MAT ed30
EDITION 30 NUMBER:- 1038 ,Forge dv,ecs dog bone insert,Tints,inpro smoked indicators,panel filter,Black badge,Black roof,Black wing mirrors,REVO stage 2,Blueflame TBE,neuspeed arb,Neuspeed drop links,KW V3,S3 Intercooler,VWR clutch and LSD,VWR 6 pot brakes,1956 vw beetle (2332cc)
Offline bacillus
Re: Dump valve?.
« Reply #2 on: 19 October 2008, 20:08 »
Why do you want one as it does nothing for performance?
Without traction power is nothing!
WhiteGTI
Re: Dump valve?.
« Reply #3 on: 19 October 2008, 20:12 »
Do you want a recirculating valve, or a normal atmospheric one?
Atmospheric creates noise
Recirculating does not create as much noise.
IIRC Atmospheric valves are not particularly good for the 2.0T engine??? Someone confirm? Although from the link below Forge do offer atmospheric blow off valves.
See this link below:
http://www.jkm.org.uk/performance/divertervalves.htm
neo66
Re: Dump valve?.
« Reply #4 on: 19 October 2008, 21:47 »
I'm not after it for a performance result, but I have heard good and bad things about what they can do!
Basically I'm undecided, I don't want to damage my engine or void my warranty but someone told me they prolonge the life of the turbo? (if you haven't noticed I'm a complete novice as this is my first turbo car). I'm just after a discreet one, not a real chavy whhssssss.
Offline Soundlab
Re: Dump valve?.
« Reply #5 on: 19 October 2008, 21:53 »
I had a Forge one on my Pulsar GTI-R (many years ago) as the raised boost caused my standard one to split.  The forge one I had was vent-to-atmosphere, but didn't make a loud "tish" noise...more a subtle fluttering sound.
On my Skyline GTR I never needed to change the standard re-cric blow-off valves and these were hardly audible from outside the car.  Inside, the only time you heard them was on turbo shuffle on part throttle.
Personally, I wouldn't change it on the GTI unless you were either raising the boost (and therefore the stock one (from what I've read) my not be up to it) OR because the stock one has become damaged.
There are clearly far more knowledgeable people on this forum than me, I'm just going off my many years experience of turbo car ownership (both of which were very modified).
Daz
Offline Hurdy
Re: Dump valve?.
« Reply #6 on: 19 October 2008, 22:23 »
Quote off Forge site:-
"Our alternative is a fully engineered solution offering both significantly improved reliability as well as valve related boost response."
For £155 it doesn't do too much, but it does give you peace of mind. :smiley:
Seat Leon Cupra Black 290 DSG
Offline joesgti
Re: Dump valve?.
« Reply #7 on: 20 October 2008, 09:33 »
forge dv valve is best to get, and if you want the whssssss then add the forge spacer to the dv valve  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline SteveS
  • GTI ED30
Re: Dump valve?.
« Reply #8 on: 20 October 2008, 10:21 »
i thought having the spacer for sound was a bad idea? the air should be recurculated not vented?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline joesgti
Re: Dump valve?.
« Reply #9 on: 20 October 2008, 10:36 »
probably right, but if it was that bad then awesome wouldnt sell them  :undecided: wouldnt have one personally.
GTI MK5
