Author Topic: rev then cut out?  (Read 1408 times)
Offline dubsport
  • TDI POWAR!
rev then cut out?
« on: 17 October 2008, 15:09 »
got the project up and running, bit lumpy but it hasnt been driven for about years. Think it needs a new manifold gasket as it sounds tho its blowing, problem is now if i rev the engine then stop the car cuts out  :sad:
the idle is hunting all the time usually below 1k revs ... also there is a weird high pitched noise then the oil, battery and temp (?) light flash and stay on ...
whats going on?
Re: rev then cut out?
« Reply #1 on: 17 October 2008, 15:28 »
what car is it? if its a digi 8v classic symptom of a dodgy idle switch :)
Offline dubsport
  • TDI POWAR!
« Reply #2 on: 17 October 2008, 16:38 »
yeah its an 8v :)
just been out and changed the oil and the idle is now staying in one spot. what does the idle switch look like?
thanks for the help :)
Offline Jay
  • balding fat cvnt
« Reply #3 on: 17 October 2008, 16:41 »
yeah its an 8v :)
Digi or K-jet?
Search and yee shall find:  :grin:
its underneath the throttle body, cant really get to it without taking the inlet boot off!
Offline dubsport
  • TDI POWAR!
« Reply #4 on: 17 October 2008, 18:03 »
ok now the temperature light just flashes and then when i rev the car the oil light flashes and a buzzer goes off  .. what the *£$& does that mean?  :undecided:
Offline Jay
  • balding fat cvnt
« Reply #5 on: 17 October 2008, 18:16 »
Low oil pressure. Did you changed the oil filter when you changed the oil? Have you put too much oil in ? That causes low oil pressure too! Could also be a fooked sensor or oil pump  :sick:
How does it feel when you rev the engine up? Do the revs pick up quick?
Offline dubsport
  • TDI POWAR!
« Reply #6 on: 17 October 2008, 18:29 »
yeah changed the oil filter at the same time, the oil level is spot on.
when i rev the engine the revs do pick up quick but when i take off the accelerator the exhaust pops and it nearly cuts out then picks up again  :undecided:
Offline Jay
  • balding fat cvnt
« Reply #7 on: 17 October 2008, 18:38 »
Check out RubJohhny's tuning guide in the maintenance section  :wink: It's always a good place to start when looking at why they aren't running too well. I think it's the sensors if the oil level is spot on, *might* be the oil pump but I'm not sure how to tell if it's gone or not  :undecided:
