Author Topic: 2Ltr 16v (9a) Engine swap ****  (Read 23983 times)
Re: 2Ltr 16v (9a) Engine swap ****
« Reply #40 on: 03 November 2008, 16:58 »
oh right i see, well if it looks liek mine then its a kr, if its noticably bulgy around the plugs then its deffo a KR. the 42mm ones are straight like the polished one wayders has
50mm:
42.5:
« Last Edit: 03 November 2008, 17:00 by rubjonny »
Offline wayders
  • Built by the germans, thrashed by the british!
« Reply #41 on: 03 November 2008, 17:37 »
RJ the code on mine is 027 133 223 AD??????????????????  :laugh:
« Reply #42 on: 04 November 2008, 11:58 »
may part numbers are for the actual gasket ;)
inlet part numbers could be anything, as they changed many times thruout the 16v development cycle.  many part numbers are unknown now too!
Offline wayders
« Reply #43 on: 04 November 2008, 15:47 »
Rj when buying clutch do i buy 9a or 020 kit? Gonna go for  Sachs one that be ok?
« Reply #44 on: 04 November 2008, 16:09 »
clutch is matched to the gearbox you're using, 9a one will be a hydro clutch so totally different.  I assume you're using the old box right, in that case you want a 210mm GTI 8v clutch, and matching flywheel.  If your GTI is an early one it might have a 200mm clutch in which case I dont think the fly is any good?  To be on the safe side any MK2 GTI 8v or 16v fly will do the job lovely.
Offline wayders
« Reply #45 on: 04 November 2008, 17:42 »
Cheers John.. Mine's a Y reg (83).. Was plannin to use my box as it was recon'd 3k ago! New clutch only fitted about month ago.. So do i need flywheel from Mk2 16v prefably?? Turnin out to be quite a thread this lol..   :wink: :wink:
« Reply #46 on: 05 November 2008, 12:18 »
do you know if it was a 210mm clutch, if so all your old gear will fit, you just need 6 new pressure plate bolts as they're use once.  Actually done a quick check and all MK1 1.8 GTIs had a 210mm clutch, so if its a 1.8 you'll be reet :)
If its a 210 your old flywheel will be fine.  just a case of checking the BTDC timing mark is set to 6 degrees, afaik it should be if again its a 1.8. Like zis:
« Last Edit: 05 November 2008, 12:20 by rubjonny »
Offline wayders
« Reply #47 on: 15 December 2008, 09:21 »
Would it be better to use kr cams and head than the 9a ones?
Offline Horney
« Reply #48 on: 15 December 2008, 09:24 »
Yes you deffo want the KR stuff on there, the 9A stuff is tepid due to the emissions regs when it was built.
Nick
« Reply #49 on: 15 December 2008, 09:57 »
no need to swap the head though, they're near enough the same.  though if you get a flowed head then its worth it.
