Hello,
We have recently added a 1997 1.4SE with 100k to the list of motors. It runs generally spot on but it doesn't like cold starts.
It will turn over and start ok and even ticks over ok but until it gets a bit of warmth in it the slightest touch of the throttle and it tries to die or splutters and coughs and then clears.
Common fault or any thoughts guys? It's just had a full oil and filter change air filter's fine been run on V-Power and been on a run often. Once it's been ticking over a few minutes it's absolutely fine and runs spot on. Seems like a 'choke' or cold start valve or temperature sensor issue maybe??
Please help as I can see as the weather gets colder it could get worse?
