Author Topic: 160 mph clocks in my j plate driver  (Read 2720 times)
Offline lowgolf
« on: 23 May 2004, 10:19 »
Is this a straight swop? My car is a 1991 and has rev counter already
<br /><br />Yeah!!!
Offline Davs mk2 16v
Re:160 mph clocks in my j plate driver
« Reply #1 on: 23 May 2004, 17:45 »
assuming the clocks have the same single plug design, they will work just fine.
if the 16v clocks are the twin plug design, im afraid they wont.
i do have a set of these hangin in my garage if u need the single plug type...  ;)
Veedubgt18v
« Reply #2 on: 23 May 2004, 20:00 »
just wondering why?
Offline lowgolf
« Reply #3 on: 24 May 2004, 00:03 »
Because everything on my car is now 90's spec, apart from engine (of course) and speedo. Just wondering if it was a straight swop. Ill take em off and have a look at the back
<br /><br />Yeah!!!
« Reply #4 on: 24 May 2004, 00:36 »
if urs is a J plate, it will have the single plug
its the '89 cars and earlier that have double plugs
Veedubgt18v
« Reply #5 on: 24 May 2004, 15:27 »
would be good if it hit 160mph. bit dodgy in  a mk2 tho!  :o
Offline lowgolf
« Reply #6 on: 24 May 2004, 15:49 »
Ive had my drive off the clock down a big hill on the A500. But it only pushes 110 ish on the flat
<br /><br />Yeah!!!
« Reply #7 on: 31 May 2004, 19:54 »
You can swap the speedos between the clocks if they have different plugs, its easy to do.
Just take out the 8 screws/bolts on the back and swap the 'L' shaped circuit board thats clipped into the speedo (it has a thin black connector that clips to the blue PCB sheet, just be carefull and it will come off)
