Author Topic: Temp light comes on and flashes?  (Read 2105 times)
Offline Shady Pioneer
  • graphic designer.
« on: 11 October 2008, 09:52 »
Yeah, so over the last couple of months it's been doing this. If I turn the engine off though it goes away and its fine for like 2 weeks and then it'll occasionally happen again.
My temp gauge is showing 90. It never goes over or under so maybe a dodgy sensor?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Temp light comes on and flashes?
« Reply #1 on: 11 October 2008, 13:54 »
My car had overheated and the light doesnt even come on lol.   What sensor is that connected too?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
kells
« Reply #2 on: 11 October 2008, 14:29 »
shady, have you checked the coolant level at all?
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #3 on: 11 October 2008, 14:55 »
If the bottle has a sensor in it replace the bottle, only about a tenner from the dealer. I work at skoda and we change loads of these.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 11 October 2008, 14:57 »
 :grin: :grin: :grin: :huh:
I would say the sensor if facked... the oil one's do similar too!!(and have made me some good money over the years :lipsrsealed:)
kells
« Reply #5 on: 11 October 2008, 16:20 »
bottle is alot more than a tenner too, try 30 quid ish for the mk 3 (Gti anyway), mk 4 ones are around 11 quid but thats a different story :kiss:
  • graphic designer.
« Reply #6 on: 11 October 2008, 17:38 »
No I haven't checked the coolant level, I'll do that first. That's the round bottle right?
My oil light flashes when I go round roundabouts too, and has a loud beeping noise when it does so, it's only when I'm doing it at speed.
It's not my oil being low though because I had a recent new rocker cover seal and for the past 2 months my oil has been the same level (on the dipstick where it's meant to be lol).
Offline ace
« Reply #7 on: 11 October 2008, 17:50 »
with regards the oil light, probably need a new oil pressure switch. think this a farily common problem. mine went on my old gti, kept beeping over 2k rpm.
you can get the switch from ecp for about £10-£15
kells
« Reply #8 on: 11 October 2008, 17:54 »
round bottle yes. deffo check the levels first, should be between the min and max line when its cold
  • graphic designer.
« Reply #9 on: 14 October 2008, 13:38 »
Musta been my coolant level, considering there wasn't very much in there!  :laugh: :laugh: :laugh:
