After a mornings toil in the sun , some of my woes seem to have been cured . I replaced the dizzy cap and rotor (which in all honesty was really shot to bits, the contacts in the cap were more carbon than brass). Disconnected the battery for an hour while I worked on her , cleaned the throttle body best I could in situ, replaced the O-ring on the breather pipe that goes into the block, replaced the fuel relay , tightened up the circle clamps on the heatshields , then replaced the rubbers on the exhaust cause the exhaust was resting on the brace at the end of the centre section (why quick fit didnt put on new rubbers I wil never know). p***ed neighbours when I re-connected the battery and the alarm went off and I couldnt find car keys to dis-arm, put splitter back on before reversing off ramps fortunatly me 4 year old stopped me before any damage done :embarassed:.
For now she seems to be running much better went for a quick spin and seems much more responsive, MFA was up in the 30's after a short trip where as before I had to do a trip of about 8 miles to get it in the mid 20's . still some noise from the heatshield but nowhere near as bad, think I might have come up with a cure for this tho , Ill let you know how I get on with this as its a bit Heath Robinson but I think it will work .
Only thing that still eludes me is the oil leak but I want to get the engine cleaned first as I think Im still clearing up the fall out from the leaky rocker gasket.
James
