Author Topic: Somethings Not right  (Read 1791 times)
ShoCk
Re: Somethings Not right
« Reply #10 on: 19 November 2008, 12:38 »
Your crank sensor might be on its way out ... my car did this and eventually ended up starting and then stalling straight away because it couldnt hold its revs.
I spent nearly a grand changing EVERYTHING ... and in the end it was the crank sensor.
ShoCk
« Reply #11 on: 19 November 2008, 12:39 »
interesting stuff, my 16v seems a little lumpy on idle, not sure wether they are like that anyway but i am going to check out the earths you mentioned anyway..  cheers.
Shouldn't be lumpy ...
Should idle just over 1,000 revs and as soon as its warmed up a little it should sit nicely below 1,000 revs like any other car ...
