Author Topic: real quick question on amp/sub  (Read 2559 times)
Offline perd999
« on: 21 May 2004, 19:13 »
hi could sum1 reali quickly jus recap me on wot i hav to do to wire an amp up from teh headunit?, ive 4 preouts Left and right whte and red plugs and teh same fo rteh right hand side
i know i need one wire from teh battery, sorry to trouble ne one? then how many wires to sub? cheers
Offline Dizzie
  • Make friends with your fast
Re:real quick question on amp/sub
« Reply #1 on: 22 May 2004, 15:50 »
power from battery to amp
ground from amp to car's shell
remote lead from headunit to amp to turn it on when you turn your headunit on (you can just bridge the power and remote terminals, but the amp will be on all the time and will drain your 12v
RCA leads from your headunit to the amp to feed it a signal.
then 2 or more wires for your speakers.
Mk4 Golf 150PD
Offline dubslug
« Reply #2 on: 22 May 2004, 17:23 »
sounds like u have done this b4 dizzie lol  ;D
1992 pearl grey 8v
Offline Dizzie
« Reply #3 on: 22 May 2004, 18:57 »
too many times.
last install took me 3 days to do and 1 and a half hours to pull out ;D
Mk4 Golf 150PD
Offline dubslug
« Reply #4 on: 22 May 2004, 23:23 »
always the way, where do u run ur speaker wires for the front, same side as power cable??
down middle or  down side with rca cables??
1992 pearl grey 8v
