Author Topic: Removing Down Pipe  (Read 1026 times)
Offline Philpy
Removing Down Pipe
« on: 08 October 2008, 20:23 »
Ive got a magnex full exhaust including down pipe, but I need to remove it. Ive undone the 6 nuts holding it to the manifold, so its now loose. However I cant seem to pull it far enough from the mid section to get it apart! How on earth do you get them far enough apart to split them?
Second question is Ive read on here you need to drop the subframe to get the down pipe out. Is this true?? Looking at it I would think I could get it through?
Offline Conker
Re: Removing Down Pipe
« Reply #1 on: 08 October 2008, 22:31 »
Have you taken the exhaust rubbers off?  If you take them off you slide the exhaust much further back to get it off the studs.
As for the sub-frame, it seems some exhausts will, some won't.  Mine didn't. Someone also said that the lower you can tilt the exhaust the more likely it will fit through the gap, so the higher the ramps/axle stands the better I guess.
Offline oakgreen_91
« Reply #2 on: 10 October 2008, 18:58 »
If you do lower the subframe be immensely careful with the bolts - I would recut or replace the bolts when you get them out
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
Offline Kingt_mk2
  • you could call it complex simplicity?!
« Reply #3 on: 10 October 2008, 19:22 »
i had to loosen my stearing rack when i had to change mine, come out a treat
:: 1988 Golf 1.8 16V ::
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #4 on: 10 October 2008, 19:27 »
It will come out without dropping the subframe however you need alot of clearance. I had to twist it right round to get it out. Its bloody tight!!
Offline richard s
« Reply #5 on: 10 October 2008, 20:04 »
to remove my downpipe i turned it upside down and jacked engine up until it cleared
Offline Philpy
« Reply #6 on: 11 October 2008, 18:24 »
Well that wasnt to bad, the hardest bit was getting it to split from the centre section. Once it was loose It slid out between the bulkhead and subframe ok. And I only had it on axle stands!
