ok there split, but not as i wanted them to be done!
yep, broke 18 bolts trying to get them split!!! First i thought was ok, i dont mind buying new bolts, until today when i tried getting the threads out!! HOLY F***ING HELL!!!!!!!!!!!!!! im never getting them out!
The wheels had some of the worst laquer peeling i've seen. Its was as if someone had pressure washed them for hours and hours using salt water!! It looks like the corrosion went down into the bolt threads as the threads of the bolts saved had lots of sh!te in. Also when removing the bolts that didnt break, you could hear a loud screaching as the threads scraped against each other.
There is no way we could have saved the ones that broke, we tried to use as much torque and go as slowly as possibly, but they just snapped without warning. ohh and to confirm what i mean by snapped/broken, the bolt head just snapped off!
What is gunna happen next is to weld nuts onto the broken bolts, so that they can be wrench out, as they are so tight in there, that mulgrips/pliers dont work. I have tried hammering on a socket, but no joy and also grinding a slot to use a flat head screwdriver, no joy.
basically, what a c***!
good news is that the refurbing side of things is going well and starting to make progress with that. More good news is that they will look PHAT when done. I think white centres with silver rim. or maybe polished centres with white rim, we'll have to see. mmmm to finish it off, black split rim bolts .......
LL
ps, i used sh!t loads of wd40/gt85
