Author Topic: mk2 rear brake setup onto mk3  (Read 6301 times)
Re: mk2 rear brake setup onto mk3
« Reply #10 on: 06 October 2008, 18:43 »
yep, or mk2 calipers/carriers, or passat, or SEAT ibiza, or polo etc etc  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #11 on: 06 October 2008, 19:24 »
what exactly am i needing?
sorry im dont know what parts are what. If i went to a scrappy or in the forum here, what exactly am i asking for?
-entire rear beam with full brake setup (mk3)
-front hubs (what is that?) with all brake stuff on (mk2)
Getting there!
cheers again for your help, i really need more stopping power!
LL ;)
« Reply #12 on: 06 October 2008, 19:31 »
do you want 256 or 280s, or are you not bothered?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #13 on: 06 October 2008, 20:37 »
well there might be 1.8t at some point, so defo 280 at the front.
Can i not just replace the front calipers and carriers from a mk3 gti as it is to fit 280mm discs on?
LL ;)
« Reply #14 on: 07 October 2008, 09:54 »
ok, 280s are more hard to find in the scrappy, but the hubs you need are pretty common.  By hubs I actually mean the 'bearing carrier' which is the part the driveshaft, suspension, track rod etc all bolt to.  You probably have 239mm brakes, on these the hub and carrier are all 1 piece, so you cannot upgrade to the larger 256 or 280 setup.
The hub on 256/280 is the same just the calipers n carriers that differ, so any 4 stud VAG car (except audis) with 256+ front brakes is what you need! Passats are plentifull in the scrappers and pretty much always have 256 front brakes!  4 stud MK3s often have 256 up front as well, plus you got SEAT ibizas etc etc.
MK3 GTI is probably the most common source of 280 front brakes in scrappies, the calipers n carriers will swap onto 4 stud hubs no bother, as long as it is the 280 setup not the later 288, which doesnt go straight on as there are no 288 discs in the right offset available in 4 stud.  You can have them re-drilled, but its a bit of a faff for 8 extra mm!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #15 on: 07 October 2008, 21:14 »
so...
- mk3 gti calipers and carriers
- mk2 gti hubs
- 280mm discs
so thats the front sorted.
Now the rear you said use a entire mk3 gti setup and just use mk2 discs, but how can you fit a mk3 gti setup and still have 4 stud?? I understand how the front goes together, just confused about the rear.
thanks m8!
LL ;)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #16 on: 07 October 2008, 22:01 »
need this for the rear??
http://cgi.ebay.co.uk/VW-GOLF-GTI-MK3-DISC-BRAKE-REAR-AXLE-SUBFRAME_W0QQitemZ180296659097QQcmdZViewItem?hash=item180296659097&_trkparms=72%3A1301|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
this is what i dont understand, as i need 4 stud, so how can i use the whole mk3 gti rear setup?
cheers.
LL ;)
« Reply #17 on: 07 October 2008, 23:57 »
because the wheels bnolt directly to the rear disc, so you fit 4 stud mk2 discs :)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #18 on: 08 October 2008, 18:33 »
ok, so that 5 stud bit is part of the rear disc? (in ebay listing pic)
cheers,
LL ;)
« Reply #19 on: 08 October 2008, 18:45 »
yep the 5 holes are in the actual disc, which is threaded.  this is what the wheel bolts to!  5stud disc -> bin, 4 stud disc = success!
