Author Topic: mk2 rear brake setup onto mk3  (Read 6300 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 05 October 2008, 20:27 »
I got a 1.4 cl, so i have 4 stud wheel fitment. Got discs on the front, so thats all cool.
however its got rear drums. now i want to upgrade these to discs. I cant use mk3 rear disc setup as its 5 stud, so this means taking it from a mk2 gti. Will i need the entire rear axle, etc and replace the whole lot or can i just bolt on the carrier/discs, etc to the current setup.
i guess the handbrake, etc will need redoing (tbh its needs doing anyway).
Ohh and hard is it too this? If i had to replace the entire lot, would the mk2 rear setup be a good fit?
Cheers peeps! kinda need better brakes in this thing.
LL ;)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: mk2 rear brake setup onto mk3
« Reply #1 on: 05 October 2008, 20:56 »
Rule number 3 of simple uprated brakes:  "Never play with the balence of brakes"
If you fit disks to your rear brakes they will over power the front disks,  causing you to do some rarther interesting 180 and 360 turns on wet corners.   As well as skiding nicely into on coming traffic.
Now,  front disks off a MK2 will fit,  you can use your callipers apparently but im not to sure about how.  A full MK2 GTI setup is a nice easy conversion.  A MK3 GTI setup is better as you have the advantage of 5 stud wheels but this means you need new wishbones and in turn need a new anti roll bar fitted. which is an absolute pig to do on a driveway.  I struggle over my inspection pit.   So If you must. Go find a MK2 GTI setup.  Its worth it  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Rmachines
« Reply #2 on: 05 October 2008, 20:58 »
Oh and yea its possible to just bolt on the new stub axle, fit the disks and caliper retainer,  then fit the calipers,  new bit of copper pipe and new hand brake cables.  If you are very brave, got for the axle jobby but be warned its a nasty job!  you will need a welder and some one who with a press (change the bushes while its out)  And not any old press. a VW one or some one whos willing to risk mushing the bushes.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 05 October 2008, 21:46 »
OK, yeah i was going to uprate all the discs all round. 280mm g60 drilled/grooved at the front and some smaller solid discs at the back. think you could pick up that lot with pads for around £150.
The fronts should be ok, not sure if they could house 280mm brakes as they are now, might need the calipers (is that right, calipers hold the pads??) off a mk2 gti.
Basically i need to find a mk2 gti in a scrappy and get the brake setup off it.
I'm confused about what i need to do a rear disc brake conversion. Can i not just remove drums and simply bolt on mk2 gti brake setup??
Cheers ross!
LL ;)
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 05 October 2008, 23:02 »
If you can find the g60 calipers,carriers etc for under £250 i will be amazed!!
The gti (inc 16v) mk2 uses 256mm discs on the front and 180mm rears. you can fit the front 256mm vented discs with your o.e calipers if yours has the 256mm solid discs and using late 16v slim pads (but i'm sure 1.4 has 239mm??) so you'll need the full lot!!
rears should bolt stright on as the mk2 and 3 uses the same hubs on the back... you'll need new cables for the handbrake tho and if fitting discs I'm sure you'll need a bigger master cylinder?
Could be worth asking rubjonny in the garage area for further help...
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 05 October 2008, 23:56 »
cheers bb, good to know that the mk2/3 have the same hubs. Yeah was worried that might need mew master cylinder to keep up lol. as for the fronts, will need to check haynes to see what my current discs are. Probs worth getting ful rear brake setup from mk2 gti and might as well get all the front setup too (carriers, calipers and discs/pads).
Probs get new discs and pads all round while im at it and spray the calipers to make them look nice. haha
will post a link in the garage section for more help too, cheers.
LL ;)
p.s. BB - i meant just get g60 spec discs, not a full g60 setup!
« Reply #6 on: 06 October 2008, 12:23 »
for rears you can use the complete MK3 GTI setup, just fit 4 stud discs ;)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #7 on: 06 October 2008, 18:02 »
how does the brake setup go together then?
i have never done anything with brakes before, so not sure how the front or rear setup is put together. Im guessing its simple bolt on/off type thing. ohh and brakes will need bleeding i guess, seeing as im taking them off, lol.
so i can take a whole setup from a mk3 gti front and rear and just buy new 4 stud discs?
cheers for help guys.
LL ;)
« Reply #8 on: 06 October 2008, 18:13 »
rear yes you can do that, fronts you need mk2 16v/G60/passat/corrado front hubs, then bolt mk3 280 calipers n carriers.
the rears the stub axles are different (they have the mounts for the rear caliper carriers) then you have the carriers n calipers.  you also need the rear brake proprsioning valve, might as well just fit an entire GTI rear beam cos then you also get the internal anti rol bar.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #9 on: 06 October 2008, 18:40 »
so mk3 setup at the back using mk2 discs and mk2 setup at the front using mk3 calipers and carriers. is this right? gunna go scrappy or look around for all the stuff soon as i know what i need.
cheers
LL ;)
