Author Topic: How many miles does everyone get to a full tank?  (Read 3005 times)
Offline richard ellison
  • Mk1 Cab 'Gertrude'
is around 150-200 ok???
Offline danhock
Re:How many miles does everyone get to a full tank?
« Reply #1 on: 20 May 2004, 09:17 »
i get 350+
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline vixteris
« Reply #2 on: 20 May 2004, 10:12 »
i reckon i get 300 plus as well  :)
Speedydub
« Reply #3 on: 20 May 2004, 10:14 »
I filled up sunday (polo) and so far have done 130 miles, and the needle is just inder 3/4 tank  8)
Offline SoundillusioN
« Reply #4 on: 20 May 2004, 12:34 »
If it's a GTI then 150 is a liitle poor, but i've never seen 300 miles out of a tank but always get way over 200. Your's seems a little thirsty! How much money is a full tank ?28?
« Reply #5 on: 20 May 2004, 15:33 »
its an early gti cab (gli)- havent actually filled it up yet, as it came with a full tank of fuel.
Its looking to get 150-200 though.
Maybe i should keep the revs lower?
« Last Edit: 20 May 2004, 15:34 by richard ellison »
« Reply #6 on: 20 May 2004, 15:53 »
It takes a couple of tank fulls and monitoring to get an accurate figure, i wouldn't go by the first tank.  I found that with a full tank, the needle will drop quite quickly but slow down, its not consistant.  With each tank full my driving varies from cruise about to rag the **** out of the old girl.  Keep the revs down if you're skint, but otherwise, enjoy.  Let me know how it goes after a couple of tanks.  Fill her up, reset the trip and drive it how you want.  if it takes ?30 and you get 250 miles out of her thats like 12p a mile.  In my opinion, thats good for a gti, especially a cab.  People who get over 300 miles can't be driving their cars that hard.  It also helps to keep the revs low untill the oil has reached a good operating temp.
shaun
Offline vixteris
« Reply #7 on: 20 May 2004, 20:56 »
i got 300 miles out of my last full tank and i do drive it hard - richard ellison has seen my driving i believe  ;) :D
i have no fuel gauge at the moment so i chose to run it til 300 miles which it did no problems.   i never broke down so i reckon i must have a very fuel economical GTI cab  :)
Offline LostBok
« Reply #8 on: 20 May 2004, 21:19 »
Mine's a Mk3, so bigger fuel tank, but it is also a bigger engine... Tend to get 300 or so from a tank. Last refuel was 330miles for just over ?40 of optimax (47 litres).
Definitely vote for keeping revs low until the engine's warm though!
As my friends will definitely testify - I drive it hard enough.... I can't wait to get the Koni/Eibach's done so I can slide around roundabouts without that wallowy Mk3 suspension cramping me though... guess my fuel consuption might just climb a bit more once I can really floor it out of corners without the car rolling around... also gonna get the Schrick high-lift cams done at the same time, so I won't know what'll push it up...
LOSTBOK
Audi A4(B6): 2.5TDi Quattro Sport: Factory fitted Xenons, BOSE, and full sports leather "Soul Black / Titanium".
Mods: All OEM: S-Line bodykit, RNS-E, Bluetooth, Audi R8 FBMFSW, SDS-High voice control, full DIS, cruise control, Aero wiper mod.
In progress: 5 x OEM S4/Ronal 'Avus' 18's & 235/45ZR18 Toyo Proxes T1-R (bah! wheels delayed until WC 27-JUL-09)
Researching: Colour DIS, Freeview and DAB tuner with iPodvid/PSP/AV in for the RNS-E.
Offline danhock
« Reply #9 on: 21 May 2004, 09:38 »
i drive mine a lot and usually very hard!!!
Its a Mk1 GTI cab with a 16V mk2 engine.
Theres not a day passes when i dont get the needle in the red!!
My fuel consumption is 30-35mpg, usually aorounf 31mpg though.
If you need to work out the fuel consumption fill it up and reset the trip counter...... when its almost empty fill righ t up again and note the litres you put in and miles on the trip counter.....
My last one was 358 miles on 50.12 litres.  358/50.12 = 7.14miles per litre.... then divide by 0.22 to get gallons. = 32.5Mpg.
