Author Topic: Engine temperature  (Read 5844 times)
Offline Tornado-red_gti
Engine temperature
« on: 19 May 2004, 08:30 »
 My engine seems to be getting very hot even after fairly short trips. So hot that I can feel the heat through the bonnet. :P
Is this normal for an 8v?
Also the temperature guage in the car is reading normal, but does the MFA have some sort of temerature reading? because mine doesn't work. :(
Offline jasonpi
Re:Engine temperature
« Reply #1 on: 19 May 2004, 09:51 »
right im having a problem with mine and it seems to be the radiator but could also be the oil!! give ur car a mini service and hopefully will sort it out and make sure ur radiator is coming on.
8 v do get hot i think normal oil temp should be 95-112 ish
Blue MK2
« Reply #2 on: 19 May 2004, 10:01 »
mt 8v gets hot quick. think its due to hot hot weather 8)
Offline GavG60
  • keep my credit cards away from me please :-(
« Reply #3 on: 19 May 2004, 10:23 »
my bonnet's always hot after a run, nothing to really worry about, engine temp goes from about 92 when warm up to 115 when beaten with a large stick ;D
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #4 on: 19 May 2004, 11:47 »
or beaten by an 8 valve ;)
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
marcus123
« Reply #5 on: 19 May 2004, 12:28 »
« Reply #6 on: 19 May 2004, 13:32 »
Thanks chaps  ;D
 I'll do a service this weekend I think.
Offline Davs mk2 16v
« Reply #7 on: 19 May 2004, 23:47 »
i think thinner oils tend to get hotter quicker, and the temperature is higher aswell.
i had 15w/40 in my car before, top temp:116
now, 10w/40 top temp: anything over 120
« Reply #8 on: 20 May 2004, 09:09 »
 I normally use Magnatec 10W 40.
But I think I'm going to use that VAG Silver stuff that people on here seem to recommend when I change the oil on saturday.
 I flushed my radiator last night.
The water was very brown!! That can't have helped?
 One more thing are you guys getting the temperature reading from your MFA?
« Reply #9 on: 20 May 2004, 10:59 »
yeah, my readings are from the MFA.
one thing i have noticed is that the fan doesnt kick in until the cooland needle has just cleared the warning light bulb.
Is that right??
