Author Topic: running rich  (Read 2170 times)
Offline garfield
running rich
« on: 29 September 2008, 09:43 »
hi all i done a service yesturday and found the old plugs were extremly black / the car always smells of petrol i had an idle problem when i first got the car fixed that but cant work out how to sort this prob any advice would be appreciated
wehay its topless
Re: running rich
« Reply #1 on: 29 September 2008, 10:14 »
more info on the car required :)
Offline garfield
Re: running rich
« Reply #2 on: 29 September 2008, 10:28 »
mk1 gti 1.8 cabby :wink:
wehay its topless
Re: running rich
« Reply #3 on: 29 September 2008, 11:29 »
ok, have you ever had the co checked out?  one thing thats free to try is to unplug the 5th inj, possibly its sticking open and overfuelling
Offline garfield
Re: running rich
« Reply #4 on: 29 September 2008, 12:44 »
no i havent and will try the injector tonight thanks mate
wehay its topless
Re: running rich
« Reply #5 on: 29 September 2008, 13:15 »
ideally you want to get a proper k-jet fuel pressure gauge on it, then you can see exactly what is going on in the metering head.  The WUR is responsible for setting the fuel pressure and hence the mixture while its warming up, but without a pressure gauge you cant really see what it is up to.  Has the car suffered from rust in the fuel system due to a rusty filler neck in the past?
Offline garfield
Re: running rich
« Reply #6 on: 29 September 2008, 13:46 »
would this be something a home tune company could sort for me or would it be easy to do myself/ive only had the car a few months .the filler neck looks ok with no rust
wehay its topless
Re: running rich
« Reply #7 on: 29 September 2008, 14:35 »
dpends on how good the tuner is, a VAG specialist should presumably have the kit.  The gauges can be bought reasonably cheap, theres a group buy over on cgti:
http://www.clubgti.com/forum/showthread.php?t=174726
and a how2:
http://www.clubgti.com/forum/showthread.php?t=81658
Start with the easy stuff though ;)
Offline garfield
Re: running rich
« Reply #8 on: 30 September 2008, 13:27 »
cheers mate
wehay its topless
