Author Topic: Air Bag fault  (Read 3350 times)
Offline kr1s77
Air Bag fault
« on: 24 September 2008, 17:23 »
hi all,
my air bag light came on the other day  :sad:. when i got round to checking it the code was 00588 Airbag Ignition Circuit - Driverside N95. i cleared it, but as soon as i turn the wheel it comes back. i've tried cleaning around the base of the wheel, thinking it may be a poor connection. has anyone had this before??
ASV 1.9 TDI 110
Offline kr1s77
Re: Air Bag fault
« Reply #1 on: 25 September 2008, 20:46 »
found out its the slip ring and its on back order at vw.
ASV 1.9 TDI 110
Offline GOLF_MK
Re: Air Bag fault
« Reply #2 on: 25 September 2008, 21:29 »
Same thing happened on mine - got a second hand wheel complete with ring for £15.....
Offline kr1s77
Re: Air Bag fault
« Reply #3 on: 22 March 2009, 13:14 »
just tried the one off my donor car and it still the same  :cry:. Last time i spoke to vw it was on back order £6, gonna give them a call tomorrow. would this fail mot because of the airbag light being on???
ASV 1.9 TDI 110
Offline boneybradley
  • Back in a Mk3...
Re: Air Bag fault
« Reply #4 on: 22 March 2009, 13:24 »
yep its an mot failure...and quite a common issue (as it gets gunked up with all sorts of interior badness!!) try gsf or euro etc as they can etc most vw "main dealer only" bits
Offline kr1s77
Re: Air Bag fault
« Reply #5 on: 23 March 2009, 17:54 »
tried gsf & ecp, they don't do it. call vw today, they said £93  :sick:, its gonna have to wait
ASV 1.9 TDI 110
Offline kr1s77
Re: Air Bag fault
« Reply #6 on: 25 March 2009, 18:53 »
I swapped over the slip ring and wheel from my donor car today, to see if there was any difference. No, its still the same, gonna try and get at the airbag control unit and try that.
ASV 1.9 TDI 110
Offline Paul86S2
Re: Air Bag fault
« Reply #7 on: 25 March 2009, 19:06 »
Airbags are not part of the MOT test, so you will not fail for having the airbag light on.
You might at the worst get an advisory note, but they cannot fail you for the light being lit.
Paul
Offline Khare
  • The bear that khares
Re: Air Bag fault
« Reply #8 on: 25 March 2009, 19:08 »
Paul
that probably depends on the mood of the tester and on the garage used.
To be on the safe side, id remove the bulb, that way, it doesn tocme on!
Offline Paul86S2
Re: Air Bag fault
« Reply #9 on: 25 March 2009, 19:23 »
Paul
No it definately cannot depend on the mood of the tester or the garage used, airbags are not part of the mot test.
Check the details on the MOT tester site.
If you think about it the only way to do a definitive test on the airbag system would be to set them off, it would make an interesting sight.
I fully checked this out before removing the airbags on my car because I also thought they would be part of the mot test and was surprised to find they aren't.
Paul
