Author Topic: oil cooler  (Read 2052 times)
Offline Gates79
oil cooler
« on: 23 September 2008, 18:12 »
which way round does the oil cooler go. Its a standard cooler that bolts up to the filter housing on a kr 16v engine
Offline Diamond Hell
  • Opinions я Us
Re: oil cooler
« Reply #1 on: 23 September 2008, 20:40 »
Pictures might help here.
VeeDubGTI16v
Re: oil cooler
« Reply #2 on: 23 September 2008, 21:10 »
smooth side goes against the filter
  • Opinions я Us
Re: oil cooler
« Reply #3 on: 23 September 2008, 23:41 »
Ah but a 'standard' cooler could be an aftermarket 'standard' one, rather than an OEM one.
Assuming stuff like it being OEM makes an ASS out of U and ME (and him).
VeeDubGTI16v
Re: oil cooler
« Reply #4 on: 24 September 2008, 08:02 »
ah but if aftermarket the oil cooler would be seperate, and the questionable item would be the sandwich plate. my moneys on oem
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: oil cooler
« Reply #5 on: 24 September 2008, 11:18 »
and the sandwich plate would still be that way around, so your not trying to put two rubber seals together.
Incidentaly, what order did you put your sndwich plate & standard cooler?  i went  housing ->standard cooler -> sandwich -> filter
all this talk of sandwiches is mking me hungry.
  • Opinions я Us
Re: oil cooler
« Reply #6 on: 24 September 2008, 12:12 »
If you're in need of sanwiches you should have a drive of this:
It's powered by 'unger.
I hear it stops well when thirsty, too (shortly before breaking down).
Offline Gates79
Re: oil cooler
« Reply #7 on: 24 September 2008, 17:05 »
Is that the filter side
« Last Edit: 24 September 2008, 17:09 by Gates79 »
VeeDubGTI16v
Re: oil cooler
« Reply #8 on: 24 September 2008, 19:00 »
yep same here.
  • Opinions я Us
Re: oil cooler
« Reply #9 on: 24 September 2008, 19:30 »
In the absence of any response from the other genii I reckon that's the filter housing side, although I've not seen one in a while as I've not done an oil change in a bit.
