Author Topic: oil cooler  (Read 2053 times)
VeeDubGTI16v
Re: oil cooler
« Reply #10 on: 24 September 2008, 19:40 »
yep looks like it, im pretty sure the other side has a raised lip
Re: oil cooler
« Reply #11 on: 25 September 2008, 10:35 »
thats the filter side, the housing side is a bit different and has metal tabs sticking up which are for the seal to hook onto (on a gen vag cooler anyway)  you'll know which way is right when you try to fit the seal, it should sit inside a recessed bit not on a flat bit
edit: filter housing side, notice the metal tabs and larger recessed area for seal to sit in
edit2: if you have an oil filter lying about, test fit it to the cooler, you'll soon realise which way is right when you see where the oil filter seal sits
« Last Edit: 25 September 2008, 12:41 by rubjonny »
Offline Gates79
Re: oil cooler
« Reply #12 on: 25 September 2008, 12:40 »
cheers fot that
