Author Topic: Cars have feelings too  (Read 2751 times)
Offline JC
  • Back in the North.
« on: 22 September 2008, 13:08 »
 :grin: :grin: :grin: :grin:
well my GTI has,  cos it knows I have been working on another Golf
so today the thermostat decided to not work, causing a reet load of back pressure which has blown the heater matrix
 :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
so after a scary tow home off the AA on a rigid bar, its been dumped in the garage, and the green machine has hit the streets.
So do i bite the bullet and change the stat and martrix just for the rolling road day, or cut my losses and pull her off the road now ????
Offline boneybradley
  • Back in a Mk3...
Re: Cars have feelings too
« Reply #1 on: 22 September 2008, 13:13 »
Of course they have feelings.....mine has allways started 100% but last week I looked at a few others to replace it and she decided not to start due to battery issues! Even with a fully charged battery it wouldn't go until yestoday and i havent done anything else to it! (that was the day I decided to keep it and not look at another till laters!)
Its got a mind!! and is good at playing tricks!!    Yours will be the same and is craving your attention!  :wink:
Offline Khare
  • The bear that khares
« Reply #2 on: 22 September 2008, 17:44 »
its actually freaky when stuff this happens. i remember a while back, i was thinking "dam i wish i got a pug or something, cheap, small, golf like, but newer and more economical. not long after the car started giving me some trouble and i had to call the AA to rescue me :sad:
cars DO have feelings :grin:
VeeDubGTI16v
« Reply #3 on: 22 September 2008, 18:26 »
put the cl on the rolling road  :afro:
Leon R
« Reply #4 on: 22 September 2008, 18:31 »
Do rolling roads measure power that low? :tongue:
Mr. Chuff, please keep your GTI. Stat takes about 20 leisurely minutes to change but as you probably know the matrix will take longer. Seems like youre just getting a bit bored of it. Up the power and you wont!
Offline Conker
« Reply #5 on: 22 September 2008, 18:35 »
Bummer mate. Look on the bright side - At least you've got the CL otherwise you'd be in more of a mess.
Did it give you any sign of something being wrong before it blew, e.g. did it overheat?
sharpie
« Reply #6 on: 22 September 2008, 18:36 »
heater matrix burns your legs/feet well good eh.
just bypass the heater matrix connecting the two pipes into the bulkhead together in a loop. not ideal but a decent temp fix.
Offline JC
« Reply #7 on: 22 September 2008, 20:32 »
well, as I have PAS, the stat aint a 20 minute job, its 35 minutes, but as I was taking it apart i have drained the PAS to change the fluid.
I also pulled the alternator off as the connections needed a good clean, - and its mounting bracket as it needed a lick of paint.
and then the SO CALLED HORRIBLE job.
1, throw away the haynes book of lies - it misses out some keys parts  :rolleyes:
2, go for it, remembering people saying about the top clips.
3, take 65 minutes to remove the offending item.
So, all i gotta do now is order the bits and then rebuild it.
Conker - Water  light was flashing - temperature was all ok.  I got stuck in traffic, stuck the heater on full and whoosh, car steamed up and footwell got all warm and damp.
Only when i investigated did I notice that the bottom hose was cold - thus the stat is stuck shut and the back pressure was too much for the Matrix. ( so says the nice AA man )
So, where do you al get ya matrixs from, have I seen somewhere that you should use a MK3 one ?????
Offline cняis
« Reply #8 on: 22 September 2008, 20:32 »
+1
this got me out of trouble a while ago... although if i were you i'd do it know in time for winter!
you will have to change the 'stat anyway.
cars and feelings... yes... without the golf's clutch failing, i wouldnt have got a decent job!
Offline cняis
« Reply #9 on: 22 September 2008, 20:35 »
ebay. from these guys. theyve always been very good, used them loads of times.
http://cgi.ebay.co.uk/VW-GOLF-MK2-MK3-GTI-HEATER-MATRIX-C39_W0QQitemZ190253044941QQcmdZViewItem?hash=item190253044941
