Author Topic: Cruise Control Help Needed  (Read 5822 times)
Offline markymark
Re: Cruise Control Help Needed
« Reply #20 on: 18 September 2008, 10:24 »
I never thought it would be so difficult to fit CC!
It isn't if you know what you are doing  :wink:
I have replied to your PM and then saw this.
The wire should only be required for cars before the end of 2005 so you should be ok.
You do not need to use 11463 for a TFSi.
Send me an autoscan of your car by email and I'll generate the correct Long Code for you.
If you are really stuck then I have done it remotely via MSN before so if you can get the car connected and with internet access I'll do it for you.
Cheers for all your help, unfortunately I only have an old copy of Vag Com so dont know if I can get "the long code" for you? TBH what is the long code?
Offline vRStu
« Reply #21 on: 18 September 2008, 10:27 »
I am assuming you and/or your installer is using a CAN capable VCDS cable?
Although for a different controller this should give you an idea of Long Coding -
http://octavia-vrs.com/cms/content/enabling-cornering-light-function
Stu
Offline markymark
« Reply #22 on: 18 September 2008, 10:30 »
He is, but im not!
Offline vRStu
« Reply #23 on: 23 September 2008, 15:01 »
Has everything been ok Mark?
Stu
Offline markymark
« Reply #24 on: 23 September 2008, 15:22 »
Yes mate thanks, I did send you a PM! :cool:
Offline Wilko2008
« Reply #25 on: 23 September 2008, 16:04 »
Its not surprising that you had problems. I had my CC retro-fitted and the dealer had problems setting mine up.
Twice I went home with the car, and the dealer telling me I would have to return as they still couldnt get it to work, as they had had to email VW.
On the second time I took the car home, I tried the CC to see what should happen & it worked!!!
Keep away from the bad people
Offline vRStu
« Reply #26 on: 23 September 2008, 16:08 »
I don't normally have any issues  :wink:
Stu
Offline SteveP
« Reply #27 on: 23 September 2008, 20:18 »
Thats because you are the don of all things VAG COM Stu  :wink:  :grin:
Are you coming along to the RR day at JKM, if so any chance of you bringing the magic cable to try again on changing the display profile on my RNS-510 and to check my fault codes to see if my dealer really did fix the diversity aerial fault? I will have some good biscuit supplies from work  :smiley:
Offline vRStu
« Reply #28 on: 23 September 2008, 20:37 »
I aim to be there mate, yes.
I'll throw the laptop in the boot for you  :wink:
Stu
Offline 182_blue
« Reply #29 on: 23 September 2008, 20:41 »
What was up with the ariel ?
