Author Topic: Cruise Control Help Needed  (Read 5823 times)
Offline markymark
Re: Cruise Control Help Needed
« Reply #10 on: 16 September 2008, 21:30 »
what is it saying ?
When he comes to switch the CC on in the ECM its saying he is barred?
Offline bacillus
« Reply #11 on: 16 September 2008, 23:21 »
it could be that you have to use the login code for your engine ECU to enable cruise control.
see if the login code of 11463 suggested in this thread works for you.
http://www.tyresmoke.net/forum/vag-com/58956-retrofit-cruise-control-audi-a3-8p.html#post683964
Without traction power is nothing!
Offline neg
« Reply #12 on: 16 September 2008, 23:22 »
to activate CC it should be pretty easy - you have to alter 2 lots of settings, first one is simply a tick box to say its got it, the second it altering a number.
Is he using the latest version of VCDS (vagcom) ?
Offline markymark
« Reply #13 on: 17 September 2008, 09:52 »
Apparently he has the upto date version of Vag Com so I cannot understand why it will not work? :undecided:
He has done the one lot of settings but I think its finding the correct binary code to change and what to change it too!
Needless to say im confused.com!  :embarassed:
Offline markymark
« Reply #14 on: 17 September 2008, 10:07 »
Any Vag Com experts near me?
Offline mrlapou
  • Mean GTi
« Reply #15 on: 17 September 2008, 10:12 »
There's a control box under the steering column, perhaps that needs to be upgraded?
I know yours is a 2007 model, but perhaps this link may help....  :nerd:
http://uk-mkivs.net/forums/p/188349/1228629.aspx#1228629
« Last Edit: 17 September 2008, 10:19 by mrlapou »
Offline markymark
« Reply #16 on: 17 September 2008, 10:21 »
Cheers for that mine has a Highline Comp so does have the correct box.
Offline mrlapou
  • Mean GTi
« Reply #17 on: 17 September 2008, 10:30 »
Okay do you think it needs the wire. This is extract from VCDS
Installation & Wiring
In general the whole retrofit is just plug and play except that one wire may need to be added.
Wire T20d/13 from steering column control module to engine control module (see wiring diagram specific your particular car/engine).
Install cruise control capable lever (see parts catalog/repair manual).
Offline markymark
« Reply #18 on: 17 September 2008, 10:34 »
That is the only thing im thinking, I have the wire but according to my fitter it doesnt need it cos it has the correct box/connections. I never thought it would be so difficult to fit CC!
Offline vRStu
« Reply #19 on: 18 September 2008, 10:18 »
It isn't if you know what you are doing  :wink:
I have replied to your PM and then saw this.
The wire should only be required for cars before the end of 2005 so you should be ok.
You do not need to use 11463 for a TFSi.
Send me an autoscan of your car by email and I'll generate the correct Long Code for you.
If you are really stuck then I have done it remotely via MSN before so if you can get the car connected and with internet access I'll do it for you.
« Last Edit: 18 September 2008, 10:20 by vRStu »
Stu
