Author Topic: what do u earth your amps to  (Read 3242 times)
Offline ricky680
  • Limited
  • Scammer
« on: 15 September 2008, 10:04 »
im having troble findinf and earth fro my amp what  are people useing as there earth
If you have sent this person money for items not received, please claim back via paypal and let topher know when you have been refunded. DO NOT send this person any more money
http://www.golfgtiforum.co.uk/index.php?topic=108469.0 See this thread for details.
Offline 95gtipete
Re: what do u earth your amps to
« Reply #1 on: 15 September 2008, 13:20 »
On one of the bolts on your rear lights is a good earthing point. Just run the cable along the side undo the nut put the earth lead on then redo up the nut.
Offline glowgtdi
  • The Derv Doctor
« Reply #2 on: 15 September 2008, 20:26 »
i got mine going to one of the nuts under the rear seats.
Offline troublestarter
« Reply #3 on: 15 September 2008, 20:59 »
use a seat belt bolt
do not to the rear light as it is not a very strong point to connect to as the bolt in the light is only held in on plastic and the metal is not particularly thick
i have had lots of customers come to me saying their amp keeps cutting out and every tgime it has been a bad earth
when fitting your earth make sure it is rubbed down to bare metal and bolted down securely
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline AdamMk2
  • Beautiful
« Reply #4 on: 16 September 2008, 19:23 »
Exactly what I was going to say  :wink:
Offline ian007miles
« Reply #5 on: 02 October 2008, 07:15 »
my earth for my amp is the bolt for the seat belts under the back seat thats the best place for it but try not to make the earth more than 12inches long ,but then its only the best place to earth it if your putting the amp on the back of the back seat or on the floor near the back seat but if you were thinking of puttin it on one of the sides use the bolt that holds the seat belt roller fingy under the shelf suports hope wot i said makes some sense.ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline GOLF_MK
« Reply #6 on: 07 November 2008, 13:48 »
Same here, no problems yet!
Offline shakeyjake
« Reply #7 on: 10 November 2008, 17:13 »
on my mk2 it's earthed to the seatbelt bolt behind the nearside boot speaker trim and in my mk3 i earthed it to one of the screws for the fuel pump access cover
