Author Topic: where is your clutch?  (Read 2049 times)
Offline ZIZZ
« on: 14 September 2008, 10:50 »
hi....
i have problem with clutch,
i did a conversion from TDI to ABF and everything is ok, but one thing (i think)
i have to push the clutch ALL THE WAY DOWN because it's 'working' on the floor.. and when i release clutch, its working from the floor....
on the tdi, it was at about half... because of the hydraulic clutch... on abf it's hydraulic too?
how does your clutch work?
sorry bout bad english, i hope you know what i mean :)
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
Re: where is your clutch?
« Reply #1 on: 14 September 2008, 10:53 »
have u tried bleeding the clutch? did u keep the gearbox the same? or have u swaped engine with gearbox?
Offline ZIZZ
« Reply #2 on: 14 September 2008, 11:05 »
i tried to bleed clutch but nothing, still the same...
the gearbox is from abf.. did the whole motor from one car to another.....
Offline AudiA8Quattro
« Reply #3 on: 14 September 2008, 11:12 »
The clutch may just have a lower biting point on the abf.
Offline ZIZZ
« Reply #4 on: 14 September 2008, 12:11 »
okay, lower... but this is so low it's on the metal... i dont know if this is normal.....
« Reply #5 on: 14 September 2008, 18:10 »
The biting point can be very low on a brand new clutch.
Offline MrTurner
  • Facelift leon cupra
« Reply #6 on: 14 September 2008, 19:44 »
How did you bleed the clutch?  Did you do it under pressure?
Offline ZIZZ
« Reply #7 on: 15 September 2008, 08:38 »
tnx 100quattro :)
2mrturner: we pumped it several times (about 10) and then bleed it... and few times like that....
like doing brakes (bleeding).. is there any other way? tnx :)
Offline MrTurner
« Reply #8 on: 15 September 2008, 09:16 »
Yes mate - get a pressure bleeding kit.  You attach one end of the bleeding kit to compressed air (a spare tyre or one of the tyres on the car - which you'll need to re-pump), attach the kit to the fluid resovoir and hey presto.
I changed my gearbox last week and bleed the clutch after.  Before the pedal was on the floor (didn't even bother to start the car), now it is better than ever.
Give it a try, the pressure bleeding kit is £16 from halfords.
Offline ZIZZ
« Reply #9 on: 16 September 2008, 17:50 »
where can i order it, because i'm not from england.. i'll try that, and i hope it's going to work...
