Author Topic: where is your clutch?  (Read 2052 times)
Offline MrTurner
  • Facelift leon cupra
Re: where is your clutch?
« Reply #10 on: 17 September 2008, 08:02 »
I'd almost guarantee it will work mate.  Try your local motor factor, or car DIY store.  I'm not sure if halfords do a pressure bleeding kit (Also on e-bay, will ship worldwide http://cgi.ebay.co.uk/Gunson-G4062-Eezibleed-Brake-And-Clutch-Bleeding-Kit_W0QQitemZ260287295148QQcmdZViewItem?hash=item260287295148&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14)
Offline ZIZZ
« Reply #11 on: 17 September 2008, 11:47 »
thank you very much  :wink:
i'll try to order that kit, and then we will see... i'll write here when i try it...
thanks  :smiley:
Offline MrTurner
« Reply #12 on: 17 September 2008, 12:14 »
The link on that kit is the exact same kit I used.  Dead simple.  The kit comes to be connected as follows:
Tyre valve (same as on a bike pump)
Which connects to the plastic bottle (you can make that out on the pic of the box)
Put brake/clutch fluid in the bottle (AFTER you've tested pressure!)
Fit cap (supplied in kit) onto resovoir
Crack the bleed nipple to make sure it's loose
Fit bleed pipe
Open tyre valve to pressure system, let it equalize, open bleed nipple until bubbles are gone.
It's all in the instructions anyway, so I've just wasted my time writing  :grin: :grin:
Offline ZIZZ
« Reply #13 on: 18 September 2008, 16:45 »
thank you :)
