Author Topic: MOT and more!  (Read 3548 times)
Offline danhock
MOT and more!
« on: 12 May 2004, 10:27 »
Had my first MOT on my Golf on Friday....
It failed on the n/s rear wheel bearing, which cost me ?4 and 10 mins to fix!!
The interesting bit was the emissions test... 660ppm for CO. Which basically means that loads of air is getting into the system some how (not a MOT failure by the way).
So i though it must be a Vacum leak (i know it was igintion related as that had been sorted before). After checking all the hoses no leaks.....  ???
So i thought id adjust the CO mixture on the Air flow meter.... Went to adjust the screw and guess what... it wasnt there!!!!
I think this may explain the emission result! without the screw im getting maximum air intake!!
Question is where do i get one of these screws!!!
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline Dizzie
  • Make friends with your fast
Re:MOT and more!
« Reply #1 on: 12 May 2004, 11:34 »
scrap yard?
Mk4 Golf 150PD
golfvr6
Re:MOT and more!
« Reply #2 on: 12 May 2004, 11:36 »
How did you change your wheel bearing in 10 mins for 4 quid?
golfvr6
Re:MOT and more!
« Reply #3 on: 12 May 2004, 11:39 »
CO is measured as a percentage
HC is measured ppm
I thought HC is down to unburnt fuel?
marcus123
Re:MOT and more!
« Reply #4 on: 12 May 2004, 11:43 »
fookin hell!
golf vr6 knows his sh!t! :D
golfvr6
Re:MOT and more!
« Reply #5 on: 12 May 2004, 11:55 »
High HC can also be down to oil consumption.
Offline JMallows
Re:MOT and more!
« Reply #6 on: 12 May 2004, 12:10 »
I'm interested in how he did the whell bearing for that, in that time! i got quoted ?50 wherever i went (for each side) Eventually got it for ?50 for both sides, but it still took an hour at least...
A clever person solves a problem. A wise person avoids it.
Offline danhock
Re:MOT and more!
« Reply #7 on: 12 May 2004, 12:37 »
just checked the emission test and it was
670ppm for HC
0.28% CO
11.3% CO2
5.4% O2
Air Fuel Ration 18.4
The Bearing were from Eurocarparts... ?3.78 for just the bearing or ?8.77 for the kit (split bin, grease cap etc..)
It does only take 10mins!! take the wheel off... remove the hub and fit... easy...
golfvr6
Re:MOT and more!
« Reply #8 on: 12 May 2004, 12:52 »
it will be alot easier on your car Dan as you have drums on the back, its a pain to get the rear discs off.
you did replace the shells as well as the bearings?
Offline danhock
Re:MOT and more!
« Reply #9 on: 12 May 2004, 13:01 »
Yep... very easy with drum brakes...
I did replace the shell too.
Do you reckon it looks like the air mix is too high then? i think so.
