Author Topic: MOT and more!  (Read 3543 times)
Offline JMallows
Re:MOT and more!
« Reply #10 on: 12 May 2004, 13:14 »
So are you saying that ?100 is FAR too much for a pair of rear wheel bearings and fitting? Oh, i also have rear drums.
A clever person solves a problem. A wise person avoids it.
Offline danhock
Re:MOT and more!
« Reply #11 on: 12 May 2004, 13:18 »
I would say ?100 is alot....
Mind you a garage would say its an hours work for each side.
say ?30 an hour and ?10 for each side parts.
I think its always worth doing as much as possible yourself.
« Last Edit: 12 May 2004, 13:18 by danhock »
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline JMallows
Re:MOT and more!
« Reply #12 on: 12 May 2004, 13:26 »
In the end some guy came out to do it, and i think it was ?40. I bought the things from G&S. I watched him do it, it took quite a while. Can't even remember what he did now though!
golfvr6
Re:MOT and more!
« Reply #13 on: 12 May 2004, 13:37 »
Deffo 2 hours work on a rear disc model, probably more, so 100 quid isn't too much.
Should only take an hour or a little more maybe on a drum brake model.
This simply because the drums can come straight off, disc brakes need to be totally dismantled.
Dan,
It sounds like your fuel mixture is TOO RICH, cos you have high level of hydrocarbons due to unburnt fuel.
You can do this yourself with a gunston colortune from Halfords.
Plug it in instead of a spark plug, connect the test spark plug to a ht lead, then observe the colour.
Adjust the co screw until you get a blue flame with orange tints in it.
It works well in the dark  ;)
Offline danhock
Re:MOT and more!
« Reply #14 on: 12 May 2004, 13:39 »
cool...
Only problem is that i dont have a CO screw...
 ;D ;D
golfvr6
Re:MOT and more!
« Reply #15 on: 12 May 2004, 13:51 »
Go to VW.
Ask them what size and length the screw is.
If they can't get one then go and buy the screw ay any hardware store.
