Author Topic: Hmm, think my temp sensor's knackered...  (Read 889 times)
Offline filthy
« on: 06 September 2008, 11:42 »
Ok, so I've been having trouble starting the old girl in th emornings recently- takes ages to fire, then coughs for a couple of minutes, then gets going and is ok for most of the day then....
Saw a post on the forum that suggested temp sensor, so I just Vag Com'd the car with the engine running, and although the car was stone cold, the coolant temp was 145 degrees C on the vagcom reading!!!!!
Now, this can't be right, so I reckon the sensor's shagged.....So, where is it? is it that little one on the right side of the head, its an ADY 8 valve engine by the way!
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline boneybradley
  • Back in a Mk3...
Re: Hmm, think my temp sensor's knackered...
« Reply #1 on: 06 September 2008, 12:25 »
try this
and all you need to do is reomove the clip, remove the wires and pull out...
Offline filthy
« Reply #2 on: 06 September 2008, 12:51 »
Ah right! Am I right in thinking that is also the temp gauge sensor? It's just that my temp gauge reads correctly...
Is there 2 parts to the sensor?
  • Back in a Mk3...
« Reply #3 on: 06 September 2008, 15:56 »
Its 1 sensor but does the ecu and gauge!!.... and you can have a perfect reading but fueling can be way out!
Offline filthy
« Reply #4 on: 06 September 2008, 18:18 »
Aha! Nice one, Muchos gracias!
