I have an (55), car registered in September 2005. though the vin shows it as an 06 model. Volume buttons are on the left, MFD controls on the right. The buttons are the same as Reds. So...when did the buttons change to this type? on the 06 Model? Purely out of geeky interest you understand....
clive, you state your car is a 06, does the vin code have a 5 or 6 in the 10th place?....I think its the 10th place, if my old memory serves me. Or have we established that your mfsw was retrofitted? check inside your service booklet theres a load of codes in there, you should have one that states (1MS) this translates in vw code terms to "leather steering wheel with Tiptronic" and as far as I can ascertain this means if you have that code on your page then your car was factory built with MFSW.
Other codes, from mine as below. The 3 digit code appears, not the description ...I got that from some reference web site or other.
B0N = component parts set, complying with vehicle type for Great Britain, various parts
CQ4 = alloy wheels 6J x 16
G1A = six-speed automatic transmission
H7D = tires 225/40 R 18 92Y xl
J1D = battery 380 A (72 Ah)
D2L = 4-cylinder gasoline engine 2.0 L/147 kW 16V turbo FSI, homogeneous, base engine is T59/T61
1AT = electronic stabilization program (ESP)
1G9 = space-saving spare wheel for temporary use, radial tire (5-hole)
1MS = leather steering wheel with Tiptronic
1NL = covers for alloy wheels
5RV = outer right rear view mirror: non-spherical
5SJ = outer left rear view mirror: convex
T59 = components for, base engine, unit 06F.C
0BF = rear stabilizer
3U3 = luggage compartment cover with luggage net
QG1 = service interval prolongation
8AY = radio/navigation system
8GU = alternator 140A
8ZH = antenna for AM/FM reception, "diversity"
1KY = disc brakes, rear
1LL = disc brakes, front
3FE = electric slide/tilt sunroof with sun screen/sunblind
3YR = door pockets with insert mats
G08 = front shock absorption
0GG = emissions concept EU 4
0Y1 = standard climatic zones
4UF = drivers and front passenger airbag with front passenger airbag deactivation
4X3 = side airbag front with curtain airbag
4K3 = radio remote controlled central locking operated from inside and safe securing
N7F = partially leather seat covering, fine embossed
5MD = decorative aluminum inserts
8RW = 10 loudspeakers (passive)
2JG = body-colored bumpers
E0A = no special edition
0AE = front stabilizer
2UC = sports version
2G7 = filler neck module 1 with insert
1JE = rear sports shock absorption
L99 = code not found :-(
0YC = weight category rear axle weight range 3
