Author Topic: ABS light stays on  (Read 2874 times)
Offline SuperSandwich4
ABS light stays on
« on: 04 September 2008, 12:20 »
Hi all,
Have noticed only recently that when I start up my MK3 GTi 16v the seatbelt and ABS light come on then turn off as per the usual but when I drive off the ABS light comes on.
Anyone know what the crack is with that? Thanks.
Offline skcollob_ho
Re: ABS light stays on
« Reply #1 on: 04 September 2008, 13:10 »
Probably one of your ABS sensors has had it. put it on a vagcom to find out which one.
A totalitarian regime, crushes all autonomy in it's drive to seize the human soul.
« Reply #2 on: 04 September 2008, 13:34 »
Am sorry not very clued on cars and don't know what you mean.
Is it dangerous if the light stays on? How much to fix it?
« Last Edit: 04 September 2008, 13:37 by SuperSaiyan4 »
Offline bored_Welsh_lad
« Reply #3 on: 04 September 2008, 13:40 »
It just means that your abs wont work correctly if you need to slam on... thus old skool braking...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 04 September 2008, 13:51 »
its an m.o.t failure too.... check this guide for info http://www.golfgtiforum.co.uk/index.php?topic=57396.0
oh yeah theres nothing wrong with old school brakes!! my lights flashes sometimes due to a sticky handbrake mech!!
Offline AlanD
  • MK5 2.0T 16v
« Reply #5 on: 04 September 2008, 13:58 »
FYI VAGCOM is the diagnostics tool used on VAG cars.
« Reply #6 on: 04 September 2008, 14:04 »
I had the MOT done a few months ago and it passed.
So if I take it to a garage that also does MOT they can fix the problem?
I looked at this VAGCOM thing and I need some sort of software and cables and stuff and hook it up to my car and check it?
Can I just take it to a garage for them to sort it out? Hope its not too expensive :-(
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 04 September 2008, 14:10 »
Yeah, most garages have it, just phone up before hand and make sure they have "diagnostic tool for VWs". Prices varrey so ask.
Offline ben1.8T
« Reply #8 on: 04 September 2008, 14:28 »
My MK3 16V done this and they said it was the ABS control unit silly money to fix.  :sad:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline pro-biotic
« Reply #9 on: 04 September 2008, 15:03 »
its going to cost you initially to plug the car in to diagnose - circa 40-80 quid..
then if its simple a few quid for a wheel sensor
if its the electronics they are 500ish brand new (i have one in the shed - plug!!)
vag-com is a good purchase especially if you know a little about cars, the price you would pay for the cabla and software is the price you would pay for one dignostic session.
i`d find yourself someone on here local and get it plugged in for beer tokens, then go from there - more than likely they will be able to help you out with repairs for more tokens... but still less than by a garage or specialist
