Author Topic: ABS light stays on  (Read 2875 times)
Offline AlanD
  • MK5 2.0T 16v
Re: ABS light stays on
« Reply #10 on: 04 September 2008, 15:19 »
Yeah, its a bit of a rip off. VW wanted £70 to clear my airbag fault (long story but all it needed was clearing in VAGCOM) Ridg from here did it for me at the Brands meet in 30 seconds, taking the biscuit they was.
Offline ben1.8T
« Reply #11 on: 04 September 2008, 15:32 »
Think mine must have been the electrics cos I got quoted about £500  :shocked:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline pro-biotic
« Reply #12 on: 04 September 2008, 15:41 »
the best thing about the electronics it the box can be swapped from valve unit to valve unit in situe so no need to remove the valve unit (20 mins) then all you do is recoded and clear fault log in vag-com in 30 seconds... secondhand units are generally 30-50 quid off a private breaker and well worth the money.
with wheel sensors i have found its best to buy genuine.
if its was the pump and valve unit you prob wont get a illumination as the electronics think everything is ok - you can keep your working electronics and swap the valve units this is a bit more involved as it involves bleeding via vagcom etc.
Offline SuperSandwich4
« Reply #13 on: 04 September 2008, 15:44 »
its going to cost you initially to plug the car in to diagnose - circa 40-80 quid..
then if its simple a few quid for a wheel sensor
if its the electronics they are 500ish brand new (i have one in the shed - plug!!)
vag-com is a good purchase especially if you know a little about cars, the price you would pay for the cabla and software is the price you would pay for one dignostic session.
i`d find yourself someone on here local and get it plugged in for beer tokens, then go from there - more than likely they will be able to help you out with repairs for more tokens... but still less than by a garage or specialist
That sounds like a plan.
Anyone from the East London area that would be able to help me out pretty please?  :embarassed:
Offline Baskey
« Reply #14 on: 04 September 2008, 15:56 »
Do they test abs on an MOT? i didnt think they did, if not are they only failing it because the light is on?
Offline pro-biotic
« Reply #15 on: 04 September 2008, 16:19 »
they should check the self diagnostics of the ABS
eg check light - then check light extigushes and stays off.
as far as the operational check i not sure you would think a brake test would indicate some abs assistance.
Offline snifferdog
« Reply #16 on: 04 September 2008, 17:25 »
