Author Topic: cd player  (Read 675 times)
Offline oliver07
  • golf gti T 200BHP
cd player
« on: 01 September 2008, 07:01 »
is it possible to get a feed to my car stereo so it comes on with the ignition as i need to keep turning it off when i switch the car off thanks.
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
Re: cd player
« Reply #1 on: 01 September 2008, 07:04 »
well i know my aftermarket sony stereo turns on and off with igination sounds like its not been connected on yours
Offline oliver07
  • golf gti T 200BHP
Re: cd player
« Reply #2 on: 01 September 2008, 07:27 »
well it was a garage that done this any ideas on what wire or wires might be wrong.
Offline ineson
Re: cd player
« Reply #3 on: 01 September 2008, 09:20 »
Post this in the Electrical section and you will have your answer in no time.
My wifes does the same, its something to do with the permanent live connection wo it, if you swap over the red and yellow push connections behind the unit then it should work (didnt on mine but it does on most apprently!)
Offline bored_Welsh_lad
Re: cd player
« Reply #4 on: 01 September 2008, 14:15 »
piece of piss to sort out...
you have a perm live and an ignition live yellow and red wires on the back of the stereo, they have either put the ignition live into the perm live socket, together ( which is quite normal as they have a double bullet socket to do this on most stereos) or they have the wires the wrong way round...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
