Author Topic: Wheel ET  (Read 1676 times)
Offline drivebycar
Wheel ET
« on: 29 August 2008, 14:03 »
Yo,
Im looking at a tasty set of Rota RB's for my car, and there is the option of 15 x 8 et 25 or et 35.
But there is a set that is 15 x 7 et 40 which are cheaper.
Im only going to have g60 arches on it so dont want anything thats going to poke out further than that, but the same I dont want anything thats gonna destroy my front arches either, especially on full lock.
Help, much appreciated  :grin:
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline tom26
  • team chumpy.
Re: Wheel ET
« Reply #1 on: 29 August 2008, 14:12 »
if your car is lowered you may encounter arch problems, i'd roll or cut away some metal - won't show anyway with G60 arches.
Offline drivebycar
Re: Wheel ET
« Reply #2 on: 29 August 2008, 14:19 »
Yeah it is lowered. Which set should I be looking at really? How expensive is it to get the arches rolled?
Offline Kingt_mk2
  • you could call it complex simplicity?!
Re: Wheel ET
« Reply #3 on: 29 August 2008, 15:24 »
an afternoon with the angle helped me get my borbet 16x9 et15 ' s on :P
:: 1988 Golf 1.8 16V ::
Offline drivebycar
Re: Wheel ET
« Reply #4 on: 29 August 2008, 16:55 »
  :laugh: hahahaha
do you get much rub?
Offline drivebycar
Re: Wheel ET
« Reply #5 on: 29 August 2008, 18:41 »
which ET should I be going for?
Offline drivebycar
Re: Wheel ET
« Reply #6 on: 01 September 2008, 09:05 »
bump
Re: Wheel ET
« Reply #7 on: 01 September 2008, 10:26 »
I have had 15x7 et24s on my car from a beemer, rears were fine but fronts rubbed a little after lowering 40mm.
I now have 15x7 et 13s  which rub at the back but not the front after I rolled the metal lip right up and chopped out the lip on the plastic arches.
Id say since those wheels are wider go for the ET35, or just go for the cheaper 7j ET40 ones which are pretty much exact oem fitment for a MK2!  Then if you like you can space them out a bit to lower the ET if the mood takes you, or go widetrack if that floats your boat!
Offline drivebycar
Re: Wheel ET
« Reply #8 on: 01 September 2008, 10:40 »
Well ideally I wanted them as wide out as possible, whilst not causing loads of problems, or being illegal  :laugh:
Re: Wheel ET
« Reply #9 on: 01 September 2008, 10:45 »
depends what you want to go for, wideness at the expense of handling but an easy life, or wideness with best handling but a fair bit of spannering involved.
either way will require arch work if you go uber wide however :)
