Author Topic: thinking of buying  (Read 1264 times)
Offline ricky680
  • Limited
  • Scammer
thinking of buying
« on: 22 August 2008, 22:46 »
hi im thinking about buying a golf gti 8v i have seen but the add says it loses revs when changeing down to first ansd pops out of reverse
If you have sent this person money for items not received, please claim back via paypal and let topher know when you have been refunded. DO NOT send this person any more money
http://www.golfgtiforum.co.uk/index.php?topic=108469.0 See this thread for details.
Offline ricky680
  • Limited
  • Scammer
Re: thinking of buying
« Reply #1 on: 22 August 2008, 22:47 »
sorrny ment to cay what could cause the car to lose revs when changing down and what u think the opoping out of revirse its a mk3 8v
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 22 August 2008, 22:50 »
popping out of reverse isnt good as the 8v boxes are weak!! it could be simple like the linkage isnt aligned but it could be the box has nearly had it (and they are quite hard to find good!!) and changing down could be many problems but a dirty throttle body, faulty relays or vacuum pipe broke is most common
Offline ricky680
  • Limited
  • Scammer
« Reply #3 on: 22 August 2008, 22:54 »
i do have a golf alreday the engine is f**ked but the gear box is good i have a load more parts i dont mind brekuing mine its upo for 450
  • Back in a Mk3...
« Reply #4 on: 22 August 2008, 22:57 »
as long as its solid (check all the usual rusty places).....£450 sounds ok and having another will make any repairs much cheaper
Offline ricky680
  • Limited
  • Scammer
« Reply #5 on: 22 August 2008, 23:03 »
its an r reg is there any certen years for the engine codes i think i will make an offer for 400 if it looks good the one i have is a p reg
  • Back in a Mk3...
« Reply #6 on: 22 August 2008, 23:06 »
should be same engine between the 2....or 90% will be....£400 will be good but still check for rust as later cars seem to suffer more!!
Offline ricky680
  • Limited
  • Scammer
« Reply #7 on: 22 August 2008, 23:08 »
so apart for the talgate where else should i be looking for rust
Offline danny_p
« Reply #8 on: 22 August 2008, 23:11 »
round the windscreen
all the VW's have gone bar 1.
Offline ricky680
  • Limited
  • Scammer
« Reply #9 on: 22 August 2008, 23:33 »
hi mate so what would u say i shold look at first for whiy it cuts out sometimes any chanxce it could be the head gasket
