Author Topic: Rear door sensor  (Read 6295 times)
Offline richw911
Re: Rear door sensor
« Reply #10 on: 20 August 2008, 23:25 »
Couple of things.  When I lock all the doors from inside, for example, when I get over 10mph, all the doors lock, but the rear nearside door lock goes down, then pops open again, every time.
When I push the button the lock and alarm the car, all the doors lock, but the lights don't flash, and I'm fairly sure the alarm isn't arming.
Right i had the same prob DEFO the door module - and no your alarm is not armed unless your indicators flash.
So tell them you want a new Door Module fitted to that door.
Offline richw911
« Reply #11 on: 20 August 2008, 23:26 »
im having a similar problem, the car locks all round, but the horn wont sound when the alarm is activated, the lights just flash
my horn has never sounded
 No horn on mine? You can enable a beep with vag com.
Offline iMation
  • G SiXtY
« Reply #12 on: 20 August 2008, 23:29 »
na having the horn beep at you when you arm would really get on my tits
i mean when the alarm is "Tripped" there is no horn. god knows why
Meh....
Offline richw911
« Reply #13 on: 20 August 2008, 23:32 »
Ah i see - loose connection on the alarm unit  :undecided:
Offline iMation
  • G SiXtY
« Reply #14 on: 20 August 2008, 23:35 »
maybe, not too fused tho, getting new alarm soon
Meh....
Offline richw911
« Reply #15 on: 20 August 2008, 23:43 »
Clifford?
Offline M4VERICK
« Reply #16 on: 21 August 2008, 00:03 »
My horn never sounds when I lock the car.
Ditto.......  Nor do my doors lock when i go over 10mph??  Is this a post 2001 spec or something VAGCOM does??
« Last Edit: 21 August 2008, 00:05 by M4VERICK »
Offline T_J_G
« Reply #17 on: 21 August 2008, 08:11 »
VAG COM enables these.
Offline troublestarter
« Reply #18 on: 21 August 2008, 14:02 »
i had this on mine the horn did not sound when arming or disarming
it needed to be activated through vagcom got that done now chirps as i arm and disarm
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline bobbarley
  • I'm kind of a big deal...
« Reply #19 on: 21 August 2008, 14:09 »
Spoke to VW today, they're not interested in fixing my car unless I pay for the inspection!!!
They reckon I have to have it done in case it isn't the sensor that's faulty, they don't want me blaming them if I tell them to replace the sensor and it doesn't solve it. And they won't order the sensor without an inspection in case it isn't needed and they're stuck with the stock.
Whatya think I should do?
